Here the side view on a set of aftermarket Forged wheels with a 14mm offset ... no spacers needed
Do you get rubbing?
Hey guys hope to get some help. Long story short I purchased after market wheels and put on 19s all around but with 30mm offset. My fault for not checking. Just found out OEM is 40mm. I'm getting rubbing only on reverse and turning. To combat this I figured spacers is the way to go.
Being the offset is 30mm and I like the way I've seen the OEM 21s posted here with 25mm/20mm spacers would that mean I need to get 35mm/30mm because of my 30mm offset?
Hmm so maybe spacers won't help then? What's causing the rubbing for me, going from 8.0" width to 8.5" width or going from 40mm offset to 30mm?
Adding spacers will make the wheel stick out more. The opposite of what you want to do.
Check out https://www.willtheyfit.com/index.p...2=45&wheel_size=19&wheel_width=8-5&offset2=30 and enter different wheel sizes and offsets to see how it affects one another.
Both. As others have stated, adding spacers prob won’t help you. Depending on how bad you’re rubbing, you may be able to heat the liner up and push on it to buy yourself a few precious millimeters. Or just not go full lock when reversing and live with the slight rubbing.Hmm so maybe spacers won't help then? What's causing the rubbing for me, going from 8.0" width to 8.5" width or going from 40mm offset to 30mm?
I believe the offset on the FRONT wheels is +30 or 35 mm for all of the OEM wheels. IIRC, the rears are +40 to clear the strut tower.
So, with that said, if you're rubbing on the outer side of the wheel well when reversing, spacers would make things worse, because you're making the "swing" of the wheel wider when you turn. As in, the edge of the tire is even farther from the hub.
I have 22's on my car and experienced rubbing when I reverse at full lock as well. I found that the tire was catching the little plastic fins on the front of the wheel well in reverse, causing the rubbing noise.
From a mechanical standpoint, this is a minor deal, but the noise is irritating. So, my plan is to grab an X-Acto Knife and just cut out the little fins that the tire rubs against. The fins aren't structural, and a few cut out won't be missed. That will eliminate the tire catching on the liner, which will stop the rubbing noise in reverse.
So, after aaaaall of that, the main reason that folks get spacers for Teslas is that the factory wheels sit about 20mm inbore in the wheel well, which makes it look like it skips leg day. It's purely cosmetic. If you like the "flush" look of wheels that sit right at the edge of the fenders (I certainly do), then spacers will fix that. If you don't care, then don't get spacers.
The only trouble with spacers is that they 1) MUST be hubcentric, or you'll get vibrations, and 2) will significantly exaserbate any existing vibrations you already have. Just something to consider. I used to have 20mm spacers on my OEM 21" turbines, but had issues with vibrations and took them off. Now I have aftermarket 22s with the proper offset to look good.
I run them on all my rims except one set. Btw that set is 10” front 11” rear so no need lolI’m thinking about fitting wheel spacers on my P85D (staggered 21” turbines) as I hate the way the wheels sit in the arches.
Anyone else running them on here? What sizes?
Not true adding spacers can stop rubbing or it can start rubbing it all depends on the offset and the type of spacersAdding spacers will make the wheel stick out more. The opposite of what you want to do.
What's the offset on your 22s?
These are 10 inch wide front rims and 11 inch wide rear rims. Front has 5mm pacer the tears have nothing
I have to imagine you rub like crazy in the front. I had my last set of wheels set flush with the fender (factory turbines @ + 30, add a 20mm spacer), and it started rubbing at 1/4 turn of the front wheel and got worse from there.
They are +30 in the front, and +38 in the back.
They are 21’s. The front are 255 30 21 and rears are 295 25 21That's really interesting - are those 20's? What's your tire size?
