I've searched through a ton of threads on this, but I can't find consensus. I called both Sunpass (Florida) and E-ZPass (NY), who both said I needed a front plate mounted transponder. That would be fine, if it weren't for the fact that I don't have a front plate and have removed the bracket.
Suggestions on where to put a front-license plate transponder when you don't have a front plate? A solution that involves velcro would be great, as I could then swap the two transponders when I was in CT vs. FL. Thanks.
