Tacket
I've been noodling over this issue for a couple winters now with the Leaf and now with the S as well. Cold is your friend in terms of long term life of the battery but hard on the short term capacity (reduces floating voltage/slows ionic flow across the cells). I leave the car plugged in whenever in the garage with the slider typically set to 50%. based on what I've read and my experience with quite a few other batteries, the combination of a 50% charge and cold should help extend the long term life of the battery. If I need to maximize range I time the topping up charge to end just prior to leaving, to warm the battery internally. I let the battery management do the rest. your battery will age and loose some range gradually no matter what you do, don't worry about it too much.
My practice is similar. Will be nice once/if we can schedule charges from the mobile app.
