I've been working on finding a way to make washing my panels a less intense process, and thought I'd share my experience.
My first attempt was using a window washer micro-fiber head and a long pole (~ $30 + $30 in buckets). While this works in theory, in addition to carrying up the pole, I also had to carry up two rectangle buckets to the roof. I would fill these on the roof with a long hose. It worked, but it was a lengthy process and buckets don't work that great on sloped roofs . I'd wipe down a few panels, then 'wash' the brush in one bucket (dirty water) and then dip in the second bucket (clean water) before walking back to where I left off. I also had trouble with the long pole, as it was a bit bendy, so I couldn't scrub off some of the tougher items as well as I'd like (aka, bird poop). It worked, but I'd spend about 2 hours on the roof cleaning. My roof is not very steep, and my house is a ranch style one-story, so not really a big deal. I also noticed that after the panels dried, there was a (not sure this is the right word) film on the panels from the tap water chemicals (I'm assuming).
I watched a few videos where panel cleaning companies tout how they wash panels, and noticed the water brushes they use. I also noted the ionized water systems they used. I did some research and realized both of those can be very, very expensive. I was looking for inexpensive as I know the gain is not going to ever provide an ROI on cleaning. I personally just like to clean them once a quarter to help reduce build-up over time.
I decided if I wanted to save myself some time and simplify, I might need to spend a few more dollars. I found a water brush on Amazon with 5M of pole that claimed to be sturdy and not bend much. It was a bit pricey, about $100 (it seems to have gone up a bit since I bought it). It took a month to arrive (which was expected before I ordered).
The brush came with everything I needed, except a 1/2" to 3/4" adapter which I picked up from a box store for $5. I also purchased a two pack of inline filters to reduce the chlorine and other chems from the tap water, these were about $20 for the pair.
I used this contraption for the first time over the weekend. While it took a few minutes to sort out how to handle, carry and manage the water tubing, I was able to wash all my 51 panels in under an hour. Since the pole is far sturdier, I was also able to scrub off the persistent things off the panels. Not having to reset in a bucket each few panels was the biggest timesaver. I was surprised at how much cleaner the panels looked after washing, and the filter helped tremendously with very little 'film' from my tap water. Overall, I'd call it a success. I will have to walk around far less to clean the panels, in less time, with fewer ladder climbs. It's not a perfect device, as even when the water valve they provide you is 'off', it is more like a suggestion than reality. More like a half-off switch .
Brush: https://www.amazon.com/gp/product/B09ZY3KNCV
Filter: https://www.amazon.com/gp/product/B07Z7ML4LW
The picture below shows the brush with three of the four extension poles attached. I was able to get four panels down comfortably, I would then get the first row from the lower section of the roof. In the lower right hand corner, you can see the inline filter attached.
The other side only has 3 rows of panels on each side, these were super easy and quick to clean.
You can kind of see how the water sprays through the brush through nozzles here. I was more interested in cleaning the panels than showing their function to an audience. I got these images as I happen to have a couple UI cameras watching the roof so I can see shading through the year, paired with a UI 360 camera for viewing cloud coverage.
Anyways, hope this helps someone in the future. Happy cleaning!
