Before you judge, hear me out.
It seems that I'm reacting to some sort of the dust or off gassing in my Model 3. I've had it for more than 6 months now and things have improved slightly but I still can't tolerate it for more than a short drive and it really sucks after saving for this car for a while. Symptoms are: warm feeling in lungs, hoarseness, generally feeling like getting a flu (while driving) and later feeling like I've been in a very smoky bar (this seems to start about a day after and last for a couple of days). Seems like an allergy or sensitivity.
If you test drove and were ok, is your M3 a different color interior? I know a lot of people were waiting for white interior.
An extreme solution is to see a functional medicine doctor. They can/will test you for pollutants, phthalates, etc. which might narrow down what is ailing you. Armed with that information you can go back to Tesla and ask where that material is present in your vehicle and go from there. Good luck!
Yes, it really is a bummer. I haven't had problems in other new-ish cars but then none were as fresh as this one in terms of factory to delivery time. Any suggestions about a good in-car filter?
Have you noticed any uticaria (hives) or rashes at all ?
I've used a Phillips GoPure in the past but never re-purchased filters for it so not currently in use with the Tesla. May not be powerful enough for your requirements.
TBH, if I were you, I'd consider something of the highest quality for a small room in your home and connect it with an inverter in your car.
Another possibility would be to get a home model suited to the size of your garage and run it constantly and park with your windows down. (unless you have items in your garage that are themselves giving off VOC's)
Wipe everything down inside your car frequently after letting it sit in the sun. IQ Air has an interesting "personal" model but not sure of it's utility here.
Usually for a new home it takes 2-3 months for VOC's to dissipate. Opening the windows is the simplest method of correcting a multitude of VOC sins.
The reason I asked if you have the black interior is because I do. I’ve been a professional commercial and industrial painting contractor for 20 years, and the very first thing I noticed getting into my new car when taking delivery was the smell of the stain on the wood trim piece. Typically Wood is stained, then sealed and varnished, but I believe they just stained this trim piece because of the feel, and because of the smell. Sealer usually “seals” this in a bit. Stain has a very distinctive smell as it’s almost always “oil based” and typically linseed oil is used. If you are allergic to anything like this, linseed or flaxseed oil, this may be your issue. The white interior doesn’t have a stained wood trim piece and I assume has a different smell.
Anyone who’s moved into a brand new house prob recognizes this smell as well, if they have wood trim that’s stained, sealed and varnished vs painted.
Just a theory I have, but might be something to check out.
Late to post here and didn’t have time to read all.
But in situation of new materials such as in mattresses, it is recommended to vacuum often to speed up the process of offgassing.
Perhaps run the vacuum regularly for a while and see if it helps.
How are things coming along? Any luck?
I feel for you OP. I'm sensitive to certain things as well. When we had some of our rooms painted I made sure we went with the low VOC paint. It helped, not as bad but still could detect it for a while. When we first got our Temperpedic matress years ago, oh god the off gassing was horrible--had to have been fresh out of the foam factory. Seriously couldn't sleep on it and used another bed in the meantime. One of the reasons I went with 3D Maxpider Kagu mats for our Teslas was that they were odorless. The typical rubber-like mats would drive me crazy otherwise and especially when your car is parked in the hot sun and accelerating it. Has running your AC/heat with the recirc off helped at all by bringing fresh air into the cabin?
The fact that the vast majority of people aren't reacting to whatever is in the car would most likely mean that it's your increased sensitivity or hypersensitivity to some chemical offgassing. Sometimes in our cars I'm definitely detecting some odor that my husband simply can't smell and I'm always amazed he can't! Generally it's when the heater is on. Fortunately I don't react as strongly as you.
I'd almost say charge up, park the car in your garage with the windows fully open and use the heater to try to "burn" the odor out. Shouldn't be any worry about having the Climate setting to On while in your garage. Is this your sole vehicle right now or can you let it "air out" while you drive something else? I hope you'll keep us update on how it's going.
