Has anyone added spacers to the stock 21” Ubertines setup? If so, what size did you add front/rear? Pix would also be nice!
Too have put spacers on but I put 25mm spacers as I wanted the maximum amount of poke!
I ordered new wheels and tires (19x10et40 275/45/19 - for comfort and the meaty look) and the Eibach springs for my MYP so may need to get rid of these soon though. Looks so good though. Ugh. If somehow I can convince my wife that I can keep both sets, I would. Haha.
Yea I’m going to see how it looks (or if the spacers even fit) with the 25mm spacers. If they have way too much poke then I’m going to buy 18mm spacers. I basically live on this website: www.willtheyfit.com hahaWith your new wheel/tire config, you'll be about 17mm's less aggressive than your current rear Uberturbine/25mm spacer setup, and about 15mm less aggressive in the front.
That’s what I’m thinking. It’d be Perfect if the eibachs gave a but of natural camber so the wheel tucks in a but more when it lowers the car but not sure how much it will. I’m getting an alignment done a week or two after it gets installed so we will see.If you're going for that look, I doubt you'd be bothered by another 8-10mm's of poke with your new wheels/tires and your existing spacers.
Looks sweet! Love the stance!Agreed! The specs for the MYP Eibach springs are mild, but it'd be my guess that it's likely to end up about the same as the LR Eibach setup. I'm approximately 3/4" lower than the stock MYP measurements I could find on the forums (ground to fender). I definitely have a healthy amount of negative camber after lowering which helped angle the tires slightly toward the fender. If that wasn't the case, I'd likely dial some in at the alignment shop. Looking forward to seeing pics!
The LR and P Eibach springs are actually the exact same. At least from looking at the model # on their site.
Love how we both have the same mudflaps. I'm actually thinking of switching to the Rallyamour flaps as they may be wider since the wheels are poking so much.
You also put 20mm on the fronts? Can I see a pic of how much poke you got? Thanks.I have a LR lowered on Eibach springs with Uberturbines, but this should give you an idea of what 20mm spacers look like with the factory MYP wheel/tire setup:
Eibach Pro-Kit
Thanks! I knew they were different springs, but I wasn't sure about the struts. Similar to other platforms that I've dealt with over the years, I wonder if as this model ages if there will be more OE parts being sold on the forums as people upgrade (e.g. MYP owner selling their low mileage...teslamotorsclub.com
Thanks! Any technical and/or range issues with the spacers?Correct, 20mm front and rear. I have the pics posted in the thread I linked to as well.
Reviving this. Curious what the consensus is for spacers on a lowered MYP on Ubertines. 20mm back/18mm front for a flush look?Does 15mm fit in the front? 20mm looks great in the back but want a little less for the front.
