Yes, I have. They do exactly what they are supposed to do. I dropped it an inch. No issues.
No, the suspension hard stops never allow that to happen.What happens when you go into cheetah mode? Do the tires rub the fender liner?
With a 1” drop, there is still room for cheetah drop without hitting the fender liners
Wow I just ordered mine last week and got rather lucky I see. As for the install, it was really easy and took my tech all of maybe 30 to 40 minutes. You dont need a rack, just jack up the wheels, pull em off and pop the links on.All the N2itive lowering links are sold out and they will have more in mid November .
Here is mine with those links that I just had installed last Friday... no issues with the Cheetah as well. Im running mark 10 on the rear which is about a 1 inch drop and 8 on the front which is close to 1 inch but short of it. This is the lowest onscreen set up but Im thinking of using the links to go lower and then run a higher onscreen set up so I have the option of going more lowwwww
Thanks for the kind words, @airborne spoon I appreciate your support! @vic55 Your S looks great! I think you have the ideal ride height.i cant tell you what to do for your new car but i have the whole N2itive kit on my car and they work amazing and i highly recommend them as a company. If they say it works on your car then I'd trust it. you can always email them with your questions.
Contact Us » N2itive.me
Contact N2itive about our adjustable control arms for your Tesla models S and X.n2itive.me
@Aggmeister2010 It's because the links are a different length on the new Plaids. While the links are adjustable there just isn't enough range to compensate for that large of a distance. Even at the minimum length either the front or back would be slammed to the ground depending on where you put the longer links.
We're only about a month out now from having them in stock again. : )
