SpudLime
Okay. Glad I’m not alone. It just seemed more natural and I don’t think about it when I disengage with the stalk.
It sounds like EAP makes you feel tense as a driver. The part I don't get is where you say "No time to look for the stalk" because I never look for the stalk, it's like a turn signal stalk - you already know where it is, you don't "look for it", you just flick it. I think with more seat time you will become more relaxed and feel more in control.
I've found the best way to exit EAP quickly and seamlessly is by using the stalk. By far.
You joined these forums a week ago, and you're asserting that I need more experience with EAP to feel relaxed and in control?
When I am about to hit something, I disengage by using the wheel. It is not safer to disengage with the stalk when you are in a safety-critical situation. This has nothing to do with how relaxed I am.
Why would I flip a stalk first before doing the necessary corrective action?
False braking event? Hit the accelerator
It accelerating way past the speed it should be going for the traffic situation? Tap the brake.
Going too slow around a bend? Hit the accelerator
Getting cut in front of? Hit the brake
A person getting too close for comfort? Use the steering wheel.
Taking over during a lane change? Use the accelerator/brake/steering.
Turn off TACC/AP because I'm now heading down the exit ramp? Use the stalk
Absolutely the most stressful part of EAP is accelerator/braking related. The false braking events alone have changed peoples driving behaviors to where they have their foot hovering over the accelerator.
I would like to point out two things:
1) Hitting the accelerator does not disengage EAP (or TACC). I use the accelerator all the time while EAP and TACC are active (and I want them to remain active).
I imagine neither of us wants the set speed of TACC to change as a result of our use of the accelerator.
My understanding from what WK057 said is that when you take over its adjusting the set speed. Now I still need to test this out a bit with TACC/AP to confirm this behavior.
I've never had the set speed adjust itself simply from stepping on the accelerator. When I release the accelerator my speed always returns to the set speed. It's very consistent that way.
That's my experience as well so hopefully this "changing the set speed" is limited to dis-engaging and re-engaging.
Of course, anytime you engage EAP, it will set your speed according to the settings you have set in the EAP setup menu.
The complaint WK057 brought up was the take over event was changing the set speed.
If you're in AP (autosteer+TACC) and you do a steering control then it simply turns off auto-steer. This means that TACC should still be going at the current set speed.
Then when re-engaging AP it should only be adding auto-steer, and not changing the set-speed at all. That's already active with TACC.
The method of take over shouldn't play any role in the set speed setting.
The "take over event" (wrestling the steering wheel control back) disengages EAP and leaves TACC active, it doesn't change the set speed.
Correct. At least that's how my Model 3 behaves.
No. When you engage EAP it is a new engagement. It follows the rules you have set in the EAP setup menu. It does not differentiate whether you are currently using TACC or driving manually. It is very consistent in this regard.
The method of take over doesn't play any role in the set speed setting. Every AP engagement follows the rules you have set in the settings. Every time. The "method of take over" is only relevant to conditions after the take over. Engaging EAP is a new event and it will behave consistently with the settings in the menu.
Yes, if you cancel with the stalk it does not reset your TACC speed. However, I frequently need to take over RIGHT NOW and I always do that with the wheel, where my hands already are... no time to look for the stalk. The habit I've developed is to do this even in situations where I have a second to spare. I guess I will be broken of that habit -- I drove all day yesterday and spent a lot of time cursing at this new "feature".
I'm not asserting anything, I'm making a (hopefully helpful) suggestion that learning the location of the right stalk (so you don't have to think about looking for it) will come naturally with more operating time. At least that was my experience. I'm sorry if I offended you.
And yes, I did join the forum recently. It sounds like you are asserting there is "pecking order" here that I was not aware of? It never even occurred to me.
In the last 6 months I haven't experienced one "safety-critical" event that required wrestling the control back using the steering wheel.
But, yes, that option is always available (as is the brake). The thing I don't like about using the steering wheel to routinely disengage EAP is that it leaves TACC engaged.
This really means you likely "take-over" in precisely the same way I do for 90% of the times you do it. Where we want to temporarily take over using the accelerator, and then release control back to it without anything disabling. I imagine neither of us wants the set speed of TACC to change as a result of our use of the accelerator.
To me its entirely unwelcome behavior.
What's the set speed going to be when you re-engage AP (without disabling TACC)?
a.) 60mph because the set speed is now the speed you were at when you took over
b.) 65mph because TACC has remained active all along, and all you're doing is re-engaging the auto-steer
c.) 70mph because re-engaging AP uses the speed setting in the EAP settings.
My answer before Thursday would have been b or c where I could understand the logic behind either. But, my interpretation is WK057 is saying a.
In what scenarios are you needing to disengage Autosteer? I did a hundred miles on it Wednesday in bad weather at night through two construction zones, and the only time I needed to touch it was when a truck crossed the line, which is hardly the fault of my car. I did stay out of the right lane as I know onramps and offramps can still cause reasons to disengage. Just curious what else is still bad, since I am not seeing patterns like I used to.
On 2018.48.12, the answer is (a). On prior releases, the answer was (b).
This is particularly obnoxious because often when I take over it's because there's a lot of traffic around and I'm moving slower than the speed limit -- often just a temporary slowdown. It used to be that I would leave TACC engaged through all of it (because unlike Autosteer, TACC usually works quite well) and just briefly (often only for a few seconds) take over steering, and then reengage and everything would be fine. Now I have to remember to reset my speed.
I was taking issue with the fact that you assumed that the problem here was that I did no know how my car works or I had not had enough time to get used to it.
I've found AP2 to be quite horrible at taking highway curves that would rate even a hair beyond gentle. Quite often when it's making a left curve with traffic immediately to the right it will get way too close to the other lane for comfort
wk057 - I have a lot of respect for your work. But I see NONE of the issues that you are mentioning. I see that AP2 takes curves perfect fine and centered - as long as I am no more than 5 miles over speed limit.
