Why do you say that the other solutions don't work. Shielding 100% of the signal isn't a small task.
Not necessarily. There's a lot of factors that come into play and black magic is generally considered one of them.they dont work because i put the fob in them and I walk up to my car and can still unlock it and drive away in it. Would that be considered not working?
aluminum foil
If I had to guess it’s probably because they don’t work.Why do you say that the other solutions don't work.
Nope. It’s like that saying: Whatever happens in Vegas, stays in Vegas.Wait, don't Faraday cages need to be grounded to really be effective? Isn't a metal 'box' simply acting like antenna in the OP's case?
Joe
It’s like this: electromagnetic fields on the inside hit the inside of the cage, induce currents on the surface of the cage, which re-radiate back into the box. Fields on the outside cause currents on the outside surface which also re-radiate back into the outside of the box: but nothing in either case goes through.
Well, there is this thing called skin depth: When an E-field hits a metal surface, it causes the electrons on that surface to accelerate; the negatively charged electrons move towards the positive end of an E-field, since said electrons are free to move. Accelerating an electron causes it to generate an E-field in the opposite direction of the impinging E-field, causing another E-field to be generated that tends to cancel the impinging E-field; the new E-field thus generated moves away from the surface at Ye Speed Of Light; i.e., it's a reflection.
In fact, that's in general why one knows that one is looking at a metal, which is defined as having free-flowing electrons: It looks shiny because all those free-flowing electrons are making reflections like mad.
The skin effect is because, in a non-superconductor, the electrons aren't quite free to move: They generally do fly about, yes, but they also tend to bump into atom nuclei, causing said nuclei to bounce more in place. Said bouncing is, actually, what temperature is all about so (no surprise, here) some of the energy gets transformed into heat. Since the free-flowing isn't perfect at the surface, some of the incident wave penetrates a bit further, accelerates some more electrons which do their re-radiation bit, cancelling out more of the incident wave, which travels a bit further, and so on. This decay as one moves in is exponential in nature; the skin depth is defined as the distance the wave travels before it's reduced in magnitude by 1/e. Twice the distance results in the wave getting reduced by 1/(e^2), and so on.
This skin depth is related to wavelength: The smaller the wavelength, the smaller the skin depth. At frequencies above 50 MHz or so with a decent conductor (copper, silver, gold, iron) the distance is measured in the micrometers. So, at 100 MHz or so, a piece of aluminum foil is thousands of 1/e deep, the attenuation is in the trillions.. so nothing is getting through. Especially if one is talking about a Mentos can, which is a heck of a lot thicker than aluminum foil!
Interestingly, this skin depth is the reason that copper bus bars in 50/60Hz power plants that are more than, say, a couple of inches thick are built hollow: There's no current flowing in the center, so there's no point in putting (expensive) copper in there. That wouldn't be true for a DC power plant, though: At DC, the skin depth is infinite, and current flows throughout the conductor.
Finishing up: Suppose that one has a TV antenna, made out of metal rods, up on the roof. For this exercise, the metal rods are presumed to be capped and hollow. When moving electromagnetic fields (i.e., TV signals) hit those rods, the rods re-radiate, and the re-radiation hits other bars up there, which also re-radiate, and so on; and the panoply of all this re-radiation ends up being selective to the direction that one is pointing the antenna (i.e., one can point the antenna at a TV transmitter somewhere and get that TV transmitter really, really well, but none of the ones to either side). But the inside of the tubes? There's absolutely nothing going on in there.
Finally.. Back in Physics 169 (Electromag), the prof in the lecture hall had his fun: He had a copper-screened cage, about 7' high on the inside. (So long as the holes in the screen are much, much less than the wavelength of any signals on the outside, such a screen acts as a solid metal box.) He had a volunteer get into the box (it had a screen door, with finger gaskets around it). He then fired up this monster machine that consisted of a spinning conductive disk, about 7' high, that had a long, thick, heavily insulated wire on it, a long insulated handle, and the prof, himself, wore this monster rubber gloves, and fired up the apparatus. It threw, I kid you not, a 4' long continuous arc from the tip of that probe to the screen of the cage. The volunteer on the inside felt nothing, of course; in fact, the volunteer put his hands flat on the inside of the screen on the opposite side of where that arc was terminating and reported, "It tickles a little." Probably from the hot air circulating around.. but not anything shocking.
And this is the reason that sitting in a metal car during a lightning storm is the safest place that one can be. Even a Tesla, with all that glass, still has a metal framework that at the DC frequencies of the lightning shot acts like a pretty good Faraday cage. (Note: car is sitting on insulative, rubber tires. But a lightning bolt that just went through a kilometer of air and hit a car isn't going to have a problem going an additional foot from the bottom of the car to the Earth.
On the other hand.. At one time I used to use this Open Air Test Facility (OATS). We'd mount a piece of electronics whose radiation we wished to measure from DC to Daylight in the OATS, which had a metal floor about 50' square and had walls and a roof that were made out of fiberglass with no metal fasteners whatsoever. The gear was mounted on a small elevator that, when down, one could put a metal cover over the hole when no equipment was being used. The center hole could be rotated and there were antennas one could mount on the inside to measure the EMF being given off by the gear. All nice and good, and occasionally the FCC would come down and test some equipment or other that they were interested in.
But if there was a thunderstorm anywhere nearby, we'd retract the gear down, cover the hole, and Get Out Of Dodge: Because any lightning bolt that came down from on high would go straight through all that fiberglass and zap anything, including people, on the inside. Fun. An anti-Faraday cage, if you will.
Oh great and knowing one, why don't they work?If I had to guess it’s probably because they don’t work.![]()
Nope. Those have some very specific features built into them and operate at a very different frequency range.
That's a little like apples and oranges because we are talking different frequencies here.I'm not trolling - this is a real question. Suppose you put your fob in a working faraday cage and there is an EMP. What are you going to do with it? Is your car also in a faraday cage? Might be a fun project to build.
Not sure I'm seeing your point.
Thank you this is helpful insight. I’m back on the hunt for ble blockerfyi, legacy X uses BLE fob while S uses RFID
maybe all those blockers are only for RFID
BLE is also the reason u CAN'T pair used fob to X
So that part that makes a differnece is not that it isThank you this is helpful insight. I’m back on the hunt for ble blocker
I'm 99% sure that it they aren't using RFID, they are using 300-400 MHz classic key fob frequencies.fyi, legacy X uses BLE fob while S uses RFID
Took the image out. But, yeah, looks a lot like boards I've designed in the past. But there are engineers who've done lots more circuit boards than I have.Wow, you really *are* "Tron" guy.
