Hmmm. I think this is an issue, because as we get into winter my ratio goes way up.Assuming your solar is what your installer told PG&E it is, I think the only way to exceed their estimated production would be to use a lot of Grid Charging and Export Everything. So maybe they found it wasn't worth the extra paper and postage.
Actually, might depend on one key thing (I think I asked this before and someone likely answered but i forgot)…is monthly export limit an actual export limit (one way) or is it net export/generation?
Below you can see in Oct I generated 944kWh from PV. Oct was not all blue sky, so let’s say 1,000kWh was ideal/theoretical PV max generation (and would be the limit for Oct by PG&E on BWbill).
Of that amount the PV exported 255kWh to the grid.
Then below, you can see my ESS’s exported 1,062kWh to the grid. NOTE: 1st half of month I lost 1of4 PW’s, so it’s lower GC and lower EE. That got fixed then it went back to the full 54kWh of ESS capacity in second half of month.
So if the PG&E limit is pure export only, then 255+1062=1,317kWh and I’ve exceeded my hypothetical 1,000kWh export limit.
This is (really) bad because 1) I’ve disallowed high-earning NEM credits at peak rates for low-earning off-peak, and 2) I unnecessarily imported many kWh’s driving up my NBC’s.
On the other hand, if it’s a net export limit, then I exported 255+(1062-1404)= -87kWh.
So I really need to know the export limits by month if the policy is the former, in order to tune my system (prob by increasing my ESS SOC reserve to >0%).
