Thats great news, considering the cost of the renovation, the cost of the charger is relatively minor as I have everything exposed.
Converting HPWC to plug-in is as easy as adding a plug to it and changing switches to work as 40A. Then you can take it with you after moving. You can apply for receptacle installation rebate as long as you bought eligible EVSE. With rebate in mind you'd get free HPWC.Ah gotcha. You’re right, I could have done that for about the same price (after the rebate) as what I ended up doing (since I bought another UMC anyway).
A major factor for me was that I know I’m moving to a different place in less than 6 months, and this way I get to take both UMCs with me (whereas I would have left the HPWC behind when I sold this place, as I would had to pay an electrician again to take it out).
NOIs it possible to get the HPWC rebate without installing the HPWC?
I know that it has the ability to pull a lot, but I thought the HPWC had a setting in it, where you tell it exactly what to pull. I have a 40amp breaker on it currently.Probably not, the hpwc has the ability to pull 80 amps regardless at what you set it at, so you would have to have awg3 to the hpwc. You probably have awg6 to your plug so I’m going out on a limb and saying it won’t pass. You could however use your rebate to have the installation done. Then swap the hpwc for a 14-50 plug and the 100 amp fuse for a more suitable size, and mount the hpwc next to it on a plug like you wished but if anyone tried to pull the full 80 you would trip the circuit breaker. Not a big deal but one you would find turned up in a home inspection.
I have a Nema 14-50 in my garage already. Can I buy the HPWC, and wire it through a power cord similar to this one: https://www.amazon.ca/General-Electric-WX09X10039-40amp-6-Feet/dp/B00NPZHBZY
Does anyone know if that would pass inspection? Or does the HPWC need to be wired directly?
There is some great discussion about this very question here: High Power Wall Charger (HPWC) vs NEMA 14-50 Direct PlugI have a Nema 14-50 in my garage already. Can I buy the HPWC, and wire it through a power cord similar to this one: https://www.amazon.ca/General-Electric-WX09X10039-40amp-6-Feet/dp/B00NPZHBZY
To expand slightly, you can claim the rebate ONLY after you show certificate of inspection of installation. So you could wire it yourself, have it inspected, then claim the rebate. The good news is the cost of that inspection also qualifies for 50% rebate.
I live in Ottawa and I’m looking into getting a NEMA 14-50 outlet installed in my garage. Does anyone have any idea how much this tends to cost? I can’t seem to find any recent posts with Canadian quotes.
Also: does anyone in the Ottawa area have any recommendations for a good electrician?
Thanks for your advice.
Just had Watson Electric in Ottawa come by and issue me a quote. The electrician mentioned that his preference was to purchase the Tesla wall-charger rather than just install a NEMA 14-50. He said either way both setups would be fine. Should be getting his quote by the end of the day. Just wondering if I can order the Tesla Charger now before I get my Tesla and still be eligible for the Ontario rebate on it? I have a reservation number only (configured the Model 3 last week).
You can, I have.
The trick is you have 3 months to plate the vehicle to get the rebate. Get the application form, it has the list of required documents. You need an ESA inspection certificate and receipt or invoice from the electrician, your plate number and registration information, and you have 3 months to get them all.
I have installed the HPWC, I think like a set of winter tires for daily use it will be more practical to have this when used on a daily basis.
It can also be mounted outside.
