Ok, so when you say over 10kW you are referring to the sizing of the PV system (PV panel output X number of panels, ie wtat you see in the Tesla configurator)? So not the sizing of the ESS/PW (I guess even one PW is exceeding that)?YRide,
I posted a while back, nothing definitive but similar to your topic: Link.
My understanding on the number of power walls is that the PG&E NEM tariff treats systems with larger capacity differently. Over 10kW, they require special metering or non-export controls, while systems under 10kW can use the "estimation methodology". (Special Condition 9, c, 2, ii). I gather this is all to minimize TOU arbitrage, grid charging off peak and exporting on-peak, by limiting export to the amount of solar production, either measured or estimated. Larger systems make larger export possible, so they want better data, it seems. Early on at least, Tesla seemed to be helping PG&E enforce their rules, but more recently some folks with 3 and more PW have reported that they can Export Everything.
In my case, with only one PW and no ITC taken, I am flying below the radar. Still, against my installer's advice, I did, opt to tell PG&E I was enlarging my solar array so that they would calculate a larger export limit, even though this meant I lost my NEM1 grandfathering.
Anyway, on both your ITC and the multi PW questions, there still does not seem to be much clarity. Oh, and the new NEM3 tariffs have not been published yet, so uncertainty reigns, I fear.
SW
I am currently designed for a 10.8kW system (27 panels X 400W), so it looks like I might run into this issue. But it sounds like PW qty should not have an impact?
