Hi, I'd appreciate some analysis on my new installation and if there's a problem with it.
I got a 8.16kW 24 panel system plus 2 Powerwalls installed in March. Located about 20 miles east of Downtown Los Angeles. Telsa Gateway 2, Tesla 7.6kW inverter, and the two Powerwalls are installed in the garage. Layout for 24 panels is shown in picture, they face slightly southeast at about 195 degrees. The system passed city inspection last week, and I paid invoice in full the day after. Now just waiting on PTO.
![IMG_9616.jpeg IMG_9616.jpeg](https://teslamotorsclub.com/tmc/data/attachments/640/640614-0b2ed147cdba9d21dbb8060bfc92df43.jpg)
I flipped the solar on a few times since the install to check the system. It's working in terms of solar charging the Powerwall and supplying the grid after batteries are fully charged, and the Powerwall with solar was able to power the entire house for 100h when I switched off power from the grid, though the battery would not be fully charged every day by sundown, and eventually after a few more days would have hit the 20% reserve in the middle of the night. On a normal night, the battery will discharge 50%, no AC running at all.
However, overall solar production seems low. Tesla's contract estimated 13,800kWh yearly production, and when I plug in my numbers into PVWatts, I get 13,730kWh. For April, it estimates production of 1223kWh, or a daily production of about 40kWh. However, on the sunniest of days in April, my system is only generating about 27-29kWh. The panels have no shading and no obstructions.
![IMG_9618.jpeg IMG_9618.jpeg](https://teslamotorsclub.com/tmc/data/attachments/640/640619-e4a804418a3834742da0979be1dada93.jpg)
I've attached pics of the inside of the boxes. The inverter has 3 wires coming from the solar panel conduit, which I assume are DC positive, negative, and ground. They are connected to the 2+ and 2- labeled inputs, and there's jumper wires above connecting 1+/2+ and 1-/2-. Does this mean all 24 panels are on one string? Or did they forget to run the line for the second string? At peak 12-1pm output, a clamp meter shows +9.5A and -9.5A on the wires coming from the solar conduit, I don't know the voltage. The two black and red output wires from the inverter to the Gateway shows 14.5A on each wire, I don't know the voltage. There is one CT in the gateway clamped onto the red wire from the inverter.
![IMG_9495.jpg IMG_9495.jpg](https://teslamotorsclub.com/tmc/data/attachments/640/640622-8c404caebf0fef9a81ec7fd264f34d89.jpg)
At the time of peak output, the inverter shows strings 1 and 2 active, each at 345V and 5.1A. Strings 3 and 4 are not connected. The AC output shows 14.1A, which corresponds to my clamp meter. The Tesla app shows solar production at 3.8kW, a little higher than what the inverter webpage shows. The most I have ever seen output is 4.1kW briefly on one day, but otherwise peak output hovers at about 3.8-3.9kW on a cloudless sunny day.
![IMG_9600.jpeg IMG_9600.jpeg](https://teslamotorsclub.com/tmc/data/attachments/640/640624-4c44e90ed495421f54f76125b95ebbdb.jpg)
Does the installation seem correct? Or is something wrong? I'd appreciate any input so I can get an idea of what's going on before I contact Tesla.
![solar.jpg solar.jpg](https://teslamotorsclub.com/tmc/data/attachments/640/640613-5b6ba5794d0be017530fd92669be4da5.jpg)
![layout.jpg layout.jpg](https://teslamotorsclub.com/tmc/data/attachments/640/640612-d7be67732d3c90b47822d97cecbc4706.jpg)
![PVWatts.jpg PVWatts.jpg](https://teslamotorsclub.com/tmc/data/attachments/640/640615-63211caf8a9c62376895d486a1788a44.jpg)
![IMG_9547.jpg IMG_9547.jpg](https://teslamotorsclub.com/tmc/data/attachments/640/640621-34a3b2e6b104848dad7c83724ee8566e.jpg)
![IMG_9549.jpg IMG_9549.jpg](https://teslamotorsclub.com/tmc/data/attachments/640/640620-5798ad00023791282e8aa719caf27c24.jpg)
![IMG_9599.jpg IMG_9599.jpg](https://teslamotorsclub.com/tmc/data/attachments/640/640623-8b5d21809f2570e4324425d9bad05b65.jpg)
