mikeash
120V charging sucks, but it can get the job done. It depends, of course, on just how long you can be plugged in, and how much charge you need. If you're just staying one night then it's probably just a bonus that saves you a little time. If you stay longer then it can fill you back up if you're patient.
As far as actually locating an outlet, I've had pretty good luck so far. Not every place I've stayed has had one, but most have. My experience is that you can't just ask them, though. They'll usually just say no, they don't have one, sorry, because they're just not familiar with what they actually do have. I scout the perimeter of the hotel myself, then if and when I locate one, I ask if I can use it. Check the building itself, as well as in the landscaping and at the base of light poles. So far I haven't found any that required running the cord across a sidewalk, so there haven't been any problems with the physical setup.
I've never had anyone tell me "no" after I found one myself and asked if I could use it. I did have one place that should have told me "no," because it turned out that the outlet I had found was on the same circuit as their waffle maker, and the combined load tripped the breaker in the morning. Oops!
For other options, check out PlugShare to see what else is available where you'll be staying. CHAdeMO chargers make for decent Supercharger substitutes, and even L2 chargers can solve the problem if you're going to be spending many hours at that location.
