This noise sounds like a nut that is loose in the door. I doubt there is a nut that is loose in there, but it's just to explain what it sounds like.
I hear a "knock" when I accelerate or decelerate. If I accelerate/brake very slowly, the noise doesn't happen. But if I drive normally, at every start I will hear the knocking sound. Same when I release the accelerator (regen is enough to trigger it at low speeds), or brake. Can reproduce 100% of the time.
From that area also comes a vibration noise, similar to a loose screw, that appears when driving on rough road (not on smooth roads). Not sure it's connected.
Anyone seen/heard this before?
Anything to do with the "torque controllers"? (the stuff that prevents you from quickly opening the door - the sound is a bit similar)
It's a Raven build from July 2019.
TIA
TIA
