Noise issues with Unplugged Performance Mild Springs.
Do you have noise issues with Unplugged Performance Mild springs.
  • None. Rides like advertised.
    Votes: 6 28.6%
  • Yes. Clicking when turning and/or clunks when driving over dips.
    Votes: 15 71.4%
  • Total voters
    21
Eibach indicates to do that. I know shops who have avoided it and it rode horribly. By trimming the bumpstop it is going to increase bump travel prior to engaging the bump stop. I can only tell you that it works and makes a massive diffference. If you don't trim it the shock will likely be resting on the bumpstop at static ride height. I've attached their PDF. If it works for Eibach it will work for the rest as well. It's critical in the rear from my experience.
  • Eibach TM3 bump stop trim.pdf
Reactions: techlogik
Does anyone have the PNs that were on their boxes? Trying to determine if I got "version 3" or something older. I just got my mild springs installed yesterday by UP and got my Eibachs taken off ( I wasn't really happy with the way they rode). While the UP Mild's ride a LOT better...they make a TON of noise when going over speed bumps at any speed. Almost sounds like they're loose or the spring coils are slapping against each other.
Unfortunately, it is hard to say what the problem is. Maybe snap some photos of the springs installed and we can look for any obvious installation issues?
Hate to say it, but this is why proper coilovers are the better option. Buy once, cry once. Paying for multiple spring installations and still having problems doesn't sound fun.
Reactions: SK360
Hello codenko,
Thank you for the update on your installation. We want to ensure that you have spoken with your Unplugged Performance Tesla Specialist or our Support Team. Please send an e-mail to [email protected]. Our team would be happy to assist you! We look forward to hearing from you soon.
-Unplugged Performance Support Team
Makes sense,...yeah it does suck. I've lowered almost every car I've owned since I got my driver's license at 16. Springs and coilovers with setups ranging from $800 BC's to $4k JIC Magic's...and I can say that not "ALL" coilovers are better. My 3 is just a daily and I'm trying to keep this build OEM+. Figured I'd give UP a try before I give up the ghost and just go back to stock. I've got another "fun" car I gotta dump money in!
Hello codenko,
I have! I think he forwarded my message to support. Thanks for responding!
I have the same issue on my M3P with unplugged springs. I got the car with the springs so unfortunately unplugged won’t do anything and just told me I needed to buy a new set that fixes the issue.
We at Unplugged are passionate in supporting the Tesla community, and carry that passion into every product we make. Please reach out to our Support team at your earliest convenience so that we can discuss your concerns and get you back on the road with confidence.
Please DM us or e-mail our team at [email protected]
Unfortunately the previous owner bought the springs so they were not covered for replacement. Dealership did switch back to stock suspension but the fender gap makes the car look alot less appealing.
Hi Folks,
Just checking in to see if anyone has more recent experience with the UPP mild springs. I recently installed adjustable Tein EduraPro Plus shocks to soften up the ride on my 2019 SR+, and they did help, but adjusting them to mostly soft, it's clear the shocks are not properly matched to the stiffer tesla springs. They also make some clunking noise in the softer adjustment range. UPP mild springs plus the Teins in a medium adjustment might be the ticket for the ride quality I'm looking for.
I am a believer in dual rate springs (coming from an off-road background), but would REALLY not want to introduce any more annoying noises to my already annoyingly noisy car.
Also, my google-fu is also lacking and I'd love to see some pics of your rides on the MILD springs if you've got 'em.
Please and thank you!
Hi Folks,
Where do you have your dampers set? Keep in mind the shocks you have a very soft up front and very stiff in the rear. With that said the fronts need to be almost at full stiff and the rear shocks set at least 5-8 clicks softer.
The Teins are currently set at 14 clicks front and rear, but I'm planning on adjusting the fronts to 8 or 10 and leaving the rears for now.
I had not heard/read that about the Teins front/rear bias (there is very little information about them anywhere online), but your comment does seem to match my observations. Do you have experience with these shocks also? Do you think they'd be a good match to the UPP mild springs?
I was the first one to test out these dampers. Tein sent me a pallet so I could do my thing. I was so excited to see an aftermarket damper that I had to get them in our hands first. I have yet to release all our information on them. We're working on a youtube channel that will help provide insight. We've done a very crude test showing the difference between the Teins and the factory dampers. Since the Tein rear damper is univeral for all 3's and Y's it seems they valved it a lot stiffer and the front is extremely soft. I actually think it's really strange because we have seen how it compares to the stock dampers. Before you go about spending money on springs please set your rear dampers to tein and the fronts between 2 and 5 for starters. This might get you where you want to be. We have tested them on all trims of 3's, RWD and AWD, so I hope that this fixes your issue. BTW always counting from full stiff so go righty tighty til it stops and then count backwards the # of clicks I advised. From there you can play with it. but retain that delta or bias from front to rear so to speak.
I think you've got the righty tighty backwards if I remember the instructions correctly. Just adjusted mine this afternoon to stiffen up the front and it did tame the wobble nicely without negatively impacting the ride much, if any. Currently at 8 front, 14 rear. I'd still love a softer, but well damped overall ride quality (less sport, more commuter). But the fronts are still making a low speed clunking noise (i.e. on imperfect residential streets) that is driving me crazy.
All the way right means full stiff, count backwards to make it soft. That's how we have always done it. Close the valve and count backwards. Did you check the top nut? Since it's not a nylock it might be backing off. This is one thing I don't like about the Teins. They don't give you a good way to hold the shaft from spinning while tightening down the shaft nut.
Did you ever end up getting the UP springs? I’m torn between Eibach, UP mild or just saying f**k it and spending the money on MPP comfort coilovers. Whichever way I decide to go, I’m pretty sure I’ll be adding toe and camber arms
I bought some nylock nuts and torqued them down to spec while holding the shock shaft with vicegrips wrapped in electrical tape. The clunk remains, so this is either an issue with the shock itself or something about how the spring is aligned on the perch. I ordered another 13mm skinny socket since redwood ghosted me on the one I ordered from them. I'm pretty sure the three nuts at the top of the strut are tight, but that's the last thing I can think to check before I disassemble the whole shebang again. Open to your thoughts!
I did not. Still rolling on Tein EduraPro Plus with stock springs. I think I'd be satisfied with the ride if I could just eliminate the noises.
I don't know if any issues specific to the M3, but spring popping is usually the spring moving around in the lower seat. This usually occurs from not aligning the end of the spring coil with the step in the lower seat. This is usually more problematic on MacPherson Struts, but I have seen it simple coilover arrangements.
Yeah, I'm aware. I grabbed it with light pressure and the pliers were wrapped in several layers of vinyl tape. Otherwise, it was impossible to reach the torque spec on the top nut--the whole shaft would just spin before you got it tightened down.
