Ok, done! Well, sort of. Brake Quiet applied, dried, and re-installed. He took it for a test drive, and all was well, including a couple of stops from 40 and 60.
Of course, on the way home, they started clicking again. Right front, I think. Did a few more hard stops from 50-60 ish to 20-ish with the car in neutral (disables regen), then drove around the block to let them cool. Home now, parked without setting the hand brake. IR gun on the fronts is in the mid 140's C, rears in the mid 120's.
Observations. Besides the clicking (which I presume means he needs to re-apply the brake quiet, right?), there is still a LOT of force needed to do a hard stop. I suppose it's better than the original brakes, but I kind of was expecting more. They did not seem to fade at all, which was nice, so if that and the better grip when wet are all I get, I will be happy. Just checking to see if it means I need to do some more hard stops, or if I'm done with that part.
Second is that there is a continuous scraping sound as I drive, audible only at slow speeds. Normal, or is there an adjustment that needs to be made?
Thanks,
Greg
p.s. Forgot to mention, these look really nice on the car!
