I'm not arguing with you, but I'm a bit troubled by the inconsistency of this particular argument. When leaving a charging station with "enough" rated range but not charging fully, he was criticised for taking rated range too literally. When he left the second morning with only 32 miles rated range, he was criticised for not taking the range estimate seriously enough. Broder may be a tool, but I'm not sure we can have it both ways. I repeat again that poor real-world range estimation is a serious problem once we get beyond the more savvy early adopters.
"Rated" range is not a range "estimate". As far as I can tell it's just the EPA range of the vehicle multiplied by the percent charge remaining in the battery.
"Projected" range is far more accurate, was not mentioned by Broder (he might not have known about it), and was recently praised by Consumer Reports.
Winter chills limit range of the Tesla Model S electric car
- - - Updated - - -
Beside outright half truths like the rest of Broder's article I have two theories:
1. That that Broder told them the wrong info so the solution was in error, and or Broder misunderstood.
2.
He did not talk with a customer support person but someone who while employed by Tesla does not fully understand the car. The 20-somethings at the Tesla mall stores typically only have done single drive or two and would not know what advise to give on hypremiling. Maybe Broder's call got though to one of them somehow.
Either way it sounds like Tesla is done here so I would not expect them to answer this one.
From the beginning, what Broder reported sounded like what you would expect the "Right" advice to sound like after playing a game of Telephone.
Knowledgeable person says "when the battery is cold, it displays less range than it should. It needs to be conditioned by being heated up before it will display the correct range. He should just turn on the heater and start driving to get the battery warm".
Interpretation "You're battery is cold, it needs to be heated up, you should turn on the heater".
The critical advice is to start driving because that heats the battery far better than the cabin heater can heat a half ton block of metal that is beneath (and partially insulated from) the cabin. But "driving" doesn't have the word heat in it so it was disregarded somewhere.
In fact many customers probably do heat the battery with just the heater, but that's when the car is plugged in. In terms of energy, its a terrible solution, especially when your goal is to maximize your range with whats left in the battery.
Similarly, after being told your range will increase by conditioning the battery, leaving with 32 miles on a 61 mile trip might make sense. Of course the battery was fully conditioned by that point, and cutting it that fine makes zero sense when you are at a working charger. I doubt anyone at Tesla told Broder to leave when he did. Based on what he has said (despite claiming to have been "cleared") I believe someone told him an hour of charging would be enough to fix his problem, so he did an hour of charging and then just left.
I always felt that stupidity was the best explanation for many of Broder's decisions, but I felt the language he used in his story was intentionally deceptive and malicious, and designed to mask his own errors. So for me the "conspiracy" was real, and the review was "fake" the the decision to do it likely happened after his drive.
