OBDII port for always on power in Model X?
sacfan
195
78
Sacramento
I’ve read seemingly all the posts since 2015 that discuss a source of always-on power for a dash cam in a Model X. My take-away is that the consensus for 2019-2020 Ravens would be to use the OBDII port. Does anyone disagree? I know that there are better ways for older Model X vehicles that no longer exist in the 2019-20 models.
Does anyone have a sense about whether I should add an in-line fuse (perhaps 3 amps) so as not to blow the difficult-to-access 5 amp fuse that protects the wiring from the OBDII port?
I REALLY appreciate all the help that I’ve received from this message board.
Thanks,
Jon
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,442
4,530
Kaneohe, HI
I've wired a Blackvue into a '16 X. I did what you suggest. Use OBD II and add a fuse. Because you are right on both accounts. Always on and hard to reach car fuse.
Qbenjamin
Frugal But Classy!
Jan 7, 2017
1,150
685
Bravos
I assume that the fuse isn't in the same spot as the 16-18 Model X (right side of the driver foot well, below/behind the MCU)?
DCGOO
1,579
916
Indianapolis, IN
Thanks,
Jon
Locate the the pigtail that is used for the brake controller (check the trailer hitch bag if you have not seen it). It connects to a 4-pin connector up above the OBD port. Once plugged in you will have a continuous 12V on the black and red wires, circuit is fused at 20 amps. It is not in any kind of bracket, just hanging. You most likely will have to completely remove the plastic panel above the pedals to find it.
See Brake controller goes where?
Reactions: Darmie
sacfan
195
78
Sacramento
I AM assuming that the fuse box IS in the same place in the 2019-20 Model X as it was in the 2017-18 Model X.
Has the location of the fuse box changed to somewhere more accessible?
sacfan
195
78
Sacramento
Thanks! This is great information. Last time you explained this in a different thread I didn’t completely understand what a brake controller is and I certainly didn’t understand that it was related to the length of wiring that comes with the tow hitch.
How does that plastic panel above the pedals come off (and go back on)?
Yesterday when I attempted to get to this area I wasn’t able to get up above the OBDII port, instead only being able to find the wiring shown in the attached photo. I assume that this is not the connector I need?
Reactions: X-pilot
Qbenjamin
Frugal But Classy!
Jan 7, 2017
1,150
685
Bravos
View attachment 532282 View attachment 532280
You have to remove the trim panel in the drivers door to access this (PITA). They pry up to come off, which takes quite a bit of tugging. Don't be alarmed, but you might break a few tabs trying to get it off. In addition, grab a beer or something when you go to put the door trim back in. The panel that goes in and under the upper portion is a drag to get back in properly. The harness on the right (white plastic cover), is the one with the continuous 12V (red wire).
Reactions: X-pilot
