Official opening of SuperChargers in Norway Aug 30th
Discussion in 'Europe' started by Johan, Aug 23, 2013.
  1. Johan
    Johan Funds for M3 secured. Contingent on wife aproval.
    Drammen, Norway
    An official e-mail from Tesla invites Norwegian customers to the offical opening of 6 Supercharging stations throughout Norway on Friday August 30th.
    Tesla have shown tremendous follow-through on getting these stations approved, built and ready in such short time. Actually quite amazing considering bureaucracy etc.
    The stations and official inaugration times are (all Friday Aug 30th):
    DOMBÅS
    11:00
    LILLEHAMMER
    13:30
    AURLAND
    10:20
    GOL
    12:45
    LYNGDAL
    10:00
    CINDERELLA
    12:50
  2. Fuzzylogic
    Fuzzylogic EU Sport 359 & S94
    The Netherlands
    They are opening 6 superchargers at once? Wow! Very Nice.
    All hydro powered i guess.
  3. Chris
    Chris Member
    Maryland
    Does anyone know what the max power output of those is? 120kw?
  4. Johan
    Drammen, Norway
    Not known, not testet by users yet. Not confirmed nor denied if the EU charge port can handle 120kW. Here is a photo of the label on the SC:
  5. widodh
    widodh Model S 85 and 100D
    Middelburg / Venlo, NL
    410V * 210A = 86kW
    But the label on top says 120kW?
  6. Bearman
    Bearman Member
    Sweden
    I wondered about that also but it does say "210A max continuous", maybe it allows more amps for a shorter time? :confused:
    Oh good news anyway, thanks Johan.
  7. Johan
    Drammen, Norway
    #7 Johan, Aug 23, 2013
    It has been said this label is identical on the US superchargers and perhaps the amps on the label is rated for continous draw...? If 15-20 mins at 120 kW is continous or not I don't know.
    Edit: like Bearman said
  8. markb1
    markb1 Active Member
    San Diego, CA
    Pretty much all superchargers are 120 kW, but none will actually charge above 90 kW at this time. That's something Tesla has to enable in the cars.
  9. evmile
    evmile Member
    San Jose
    The Mennekes connector for the EU Tesla Model S has four high current pins. I wonder if Tesla has configured them as two power and two ground for DC. Each pin is rated at 125 A so a limit of 210 A for a pair is reasonable. Unfortunately this will limit EU cars to 86 kW or less for charging. The 120 kW Supercharger will have more power to share if two cars are present but the charge time is limited by the connector.
  10. J-Philipp
    J-Philipp Member
    Senlis (France)
    Awesome !
    Wish I could have the same news to share in France.
  11. Johan
    Drammen, Norway
    Check the 3-phase EU thread. The inlet has been measured to have 46 mm deep holes instead of 40 mm (common Mennekes type 2 inlet). No one has seen an actual EU supercharger male plug. There could be other differences to increase contact area and hence max current.
  12. gregincal
    gregincal Active Member
    Santa Cruz, CA
    We have a picture of a completed supercharger station posted, somebody just needs to have a look!
  13. evmile
    evmile Member
    San Jose
    But the 120 kW Supercharger label says the "output" is limited to 210 Amps.
    So unless this is for each of the two pins the 86 kW limit would apply.
    If they did improve the pins to support 210 A each then you could support 172 kW (?) based on the connector.
  14. Johan
    Drammen, Norway
    Not sure about that. What I'm saying is I'm pretty sure that I've read that the markings on the current US superchargers say exactly the same thing, namely "Output current: 210A continuous". However, there has been no talk from Tesla about replacing the physical chargers as they increase the charge rate to 120kW. And the Voltage must stay the same since that is the voltage of the battery pack as a whole. So the only conclusion is that the superchargers can deliver well over 210A continuously, right?
  15. Discoducky
    Discoducky Active Member
    Seattle
    6 at once! So cool! Who will be the first to hit them all?
  16. markb1
    San Diego, CA
    Yes, the US superchargers say the same thing. The amount of time that it's charging above 210A may be short enough that it's not considered continuous.
  17. Johan
    Drammen, Norway
    So maybe the argument is what the definition of "continuous" is when it comes to electrical standards and ratings.
  18. stopcrazypp
    stopcrazypp Well-Known Member
    From existing pictures of the "Supercharger 120"s installed in the US, the specs on the label are exactly the same line for line:
    http://www.teslamotorsclub.com/showthread.php/10733-SuperCharger-Launch/page3?p=202717&viewfull=1#post202717
    http://www.teslamotorsclub.com/showthread.php/14394-Harris-Ranch-Superchargers-and-Supercharging-Software-Update/page10?p=313192&viewfull=1#post313192
    Anyways, congratulations to all those in Norway. Having 6 superchargers at once really is a pretty big accomplishment.
  19. Johan
    Drammen, Norway
    OK, so here are fresh off the press snapshots of the actual plug of an EU superchargers. No measeurements (dimensions) yet.
    I personally like the thickness of the whole thing, both the contactors and the cable. Looks like it can carry some significant current!
    Credit goes to user KnutGol from the Norwegian forum (he lives close to the Gol supercharger)
  20. lolachampcar
    lolachampcar Well-Known Member
    WPB Florida
    As a Florida MS owner, I am jealous of the all at once roll out. By the end of Aug you will have more SCs than we have and I am reasonably certain we have more cars.
    As a shareholder, I am very excited that Tesla is hitting the European market over the head with a big hammer in showing them that MS is real and distance travel is a reality provided there is demand.
    Nicely done Tesla.
