Hi everyone feel like a typical one time forum user but I really am stuck with this so I’m looking for guidance/suggestions
Have a Model 3 and have an Ohme ePod charger (untethered) which was supplied and fitted by octopus. My problem is I seem to only be able to charge the car once and then the car is stuck on the last charging session and won’t initiate a new charging session. Schedules are active and if I unplug the car the app can see it’s unplugged and vice versa if plugged in. The only fix I’ve found so far is to contact Ohme technical support and for them to delete the charger from the account and then I set the car up with the charger again. Quite a nuisance especially as I’m on holiday and just want the car to stay at about 60% to keep the battery from going flat! Has anyone else had this problem there’s no way I’m the only one affected? Tech support are good but I don’t see the point in me paying £1k for a charger for me to contact tech support every time I need to charge the car…are other chargers more reliable? I’m guessing it’s something to do with the charger/car/app not knowing that it needs to start charging to the active schedule.
