azbob
The hitch weight on the FC 20 is 631 lbs dry. The limit on the X is 500 lbs. I do not believe it is a reasonable option.
Thanks Ohmman. I was not aware of the 500lb hitch weight limit on the Model X. Will go with the Sport 22ft.
I'm going on our first overnight tomorrow. I'll see if it's helpful, but my recollection is that I can see the front of the Airstream and some minor windows to the sides. I don't think it's useful for much else besides hitching the trailer (and it's very useful for that).A related question: I'm wondering if you found your X rear camera of any use when towing. It seems like it would be because it is such an extreme wide angle view that it can provide some visibility of your X rear quarter area. Combined with a rear view camera on your Airstream I would think they would show you everything you need to see. What do you think?
I think you'll be happy with that choice. The narrower frontal area will give you more range than with the wider Flying Cloud, and I understand that the 22' Sport is one of the most stable trailers to tow, easily besting the 16' Bambi.Thanks Ohmman. I was not aware of the 500lb hitch weight limit on the Model X. Will go with the Sport 22ft.
If I could bring it to a connection point in the front of the vehicle and install a toggle switch, I could toggle between the rear view on the X and the rear view on the Airstream, seeing either one on the 17" display. That would be the ideal setup, in my opinion.
Yes, this is definitely a viable option. I have looked at fresh water bladders as well, for example the 30 gallon variety of this one. The nice thing about the bladders is their storability after use. The other upside is that we could take the bladder (or the 5-gallon containers you mention) and go refill them while dry camping without moving the trailer.I was wondering if you could help your water and tongue weight issues by carrying potable water in 5 gallon containers, stored to the rear of the Airstream, then filling the trailer's tank on arrival? How much water does the built-in tank hold?
A 30 gallon bladder is going to weigh about 250 lbs when full. How would one maneuver it into position to fill the trailer's freshwater tank?I have looked at fresh water bladders as well, for example the 30 gallon variety of this one.
The bladder is left in place. One uses a pump and a hose to transfer the contents to the fresh water tank. Once it's empty, fold it up and move it.A 30 gallon bladder is going to weigh about 250 lbs when full. How would one maneuver it into position to fill the trailer's freshwater tank?
Okay, I see: you leave the bladder in the tow vehicle and pump the water into the trailer tank. Problem solved!
Our first trip is complete, with a nice warm-up to Wright's Beach Campground in the Sonoma Coast State Beach. Obligatory photos follow the detail. First, the summary:
Outbound: 51.0 miles, 29.4kWh, 577Wh/mi
Return: 51.0 miles, 32.9kWh, 646Wh/mi
Total trip: 102.0 miles, 62.3kWh, 611Wh/mi
I decided to completely drain the fresh water tank and pull it empty in order to get the tongue weight below 500lbs. I also loaded two 66 quart Sterilite bins full of our heaviest items and put them as far behind the trailer axle as possible - in the bathroom. After loading up the rest of the trailer, I measured the tongue weight at about 420 lbs. I lightly loaded the rear of the X (behind the axles) to ensure that wasn't added to tongue weight. I won't go into too much more, as this is probably better suited my weight distribution thread instead of here. Suffice to say, I felt I had probably accounted for the tongue weight limitations on the X, and doing so wasn't simple. Lesson to anyone shopping -- be careful on published tongue weight, as they are notoriously inaccurate.
The drive to Wright's Beach from our house goes through windy and hilly two lane roads, mostly. I dealt with traffic lights and stop and go driving near my home, and then again through Petaluma, but mostly I was driving near-constant speed on California Highway 1. The portion of Highway 1 that is inland has a speed limit of 55 and improved shoulders, and travelers frequently drive 65 and higher. I tried to stay right around 55, but found that when I'm not focused on speed, and paying more attention to hauling my trailer, my speed would creep higher. A few times I was closing in on 65 when I started slowing back down again. We stopped at Bodega Dunes Campground to fill with water, and went on to our campsite. I hoped the 6 mile very slow drive wouldn't be an issue with the added weight near the front of the axle.
I won't go into too much detail on the campground, since it's not X specific, but our site was sadly quite muddy from the recent rains. I didn't bother setting up camp outside of the trailer, just a mat to drop our shoes on before coming in. We spent the day at the beach until sunset, then returned to the trailer for dinner and games, showers, and bed. This morning we took walks down the beach and up over the surrounding cliffs before departing.
We were able to keep our furnace running all night, LED lights on, water pump running, radio, etc. I kept my eye on the voltage at the battery and found that so long as I had my 7-way connector attached, we were charging the battery. That was even with the X locked and "off". Hey, pretty cool.. or was it? Turns out that 10-gauge run is extremely ineffective, and it appears it was quite lossy along the way. I left for the trip with a full battery, used 62.3kWh, and returned home with 9% (22 miles of range). Where'd the rest of my range go?! Maybe through that 7-way, maybe not. I'll pay closer attention next time.
On the return, we stopped again at Bodega Dunes, this time to dump our tanks, then continued on our way. I kept my speeds lower but consumption was significantly higher due to (I'm guessing) the mild headwinds.
Overall, a success with some lessons to learn. First, continue to solve the tongue weight balance issue so that I can do it without using a scale every time I adjust, and also allow myself to travel with a full water tank longer than 6 miles. Next, figure out what's going on with the 7-way, and detach it if necessary (I have battery update plans for the trailer anyway). And finally, SLOW DOWN or use TACC more often to keep me slower, even on 2-lane roads.
Sorry for the lengthy post. Here are a few photos to reward your patience.
Here you go. Towing - Weight Distribution Hitch compatibilityWhere would I find your weight distribution thread?
Okay, so I assume one would place the bladder inside the trailer when empty and then fill it with a hose. Then later pump the bladder contents into the trailer tank.I think the bladder is inside of the trailer behind the axle to reduce the tongue weight
I think you're misunderstanding the way it could be used. The 30 gallon bladder is 36" x 36" x 14". If one were to use it to balance the tongue weight, a practice I believe is unnecessary except in certain heavily front-loaded situations, here's how I see it working. Place the empty bladder in the back of the travel trailer after hitching up and packing the trailer. In my case, the bladder would go in the bathroom. Run a hose and fill it between 2/3 and full. Drive to destination, hook up hose and 12V water pump, and fill trailer fresh tank from the bladder.Okay, so I assume one would place the bladder inside the trailer when empty and then fill it with a hose. Then later pump the bladder contents into the trailer tank.
But you still need a space in the trailer to keep the bladder when it is full of water. Even a 20 gallon bladder is pretty big, and at over 160 lbs not something you can move around when full. Even a 10 gallon bladder at over 80 lbs is too heavy for most people to move, particularly since it is not rigid and hard to get ahold of.
I certainly was. Thanks for the clarification. Now I get it!I think you're misunderstanding the way it could be used
And that is certainly an advantage of a flexible bladder. I would get a bladder just for that capability alone.For continued dry camping, one could drive the X to a nearby potable water source, fill up the bladder, and return to the trailer to refill with the 12V pump
Yes for your specific trailer I can envision how that would work. For the trailer I plan on buying I don't have that much space. I can see how a smaller bladder might work for me.Perhaps you see a 3'x3' space being difficult to find during travel
Yes, as I mentioned, I don't see it being necessary. There are other measures I can take to offset the tongue weight without that much trouble. I could see it being useful on a long, months-long cross-country type trip when the front under-bed storage is full of needed belongings.But the whole process of filling the bladder in the trailer before starting out, adjusting the amount of water in the bladder to get the right tongue weight, driving, then at the campsite pumping the bladder into the trailer tank, seems like a hassle that I hope to avoid.
Exactly. My situation will be somewhat unusual. Maybe the two big LiFePo batteries I plan to get and place upfront will be sufficient.I think your challenge will be to increase your tongue weight, not decrease it.
