Today for the first time I am receiving notifications on my iPhone from the OVMS app, such as "Vehicle Alert #1165: Key in Key Switch Door Ajar". Is this change in behavior a result of the recent app update? Is this controlled by parameter #3, Notifications? AFAIK, that parameter value has not been changed.
I've seen codes like that as well Mark, I believe they had something to do with undervolting during charging.
Also, I believe there are no notifications coming through since september 24th.
Hi Mark
Not sure if you prefer posts here or email support @ openvehicles (dot) com ?
anyway - OVMS + GEOsim all works FAB :smile:
Since I've had it gives the following Vehicle Alert Code: TR2S/1173 (00002000)
sometimes a few times a day, sometimes rarely - what is it ?
(both ios and android)
I get other codes but they are obvious (eg door open key in ignition etc.)
thanks
Mark
Mark,
The issue is most likely that your car is generating debug-only alerts (in your case #1173). While the in-car VDS can differentiate between debug alerts (which are suppressed unless the VDS is in debug mode) and normal alerts, OVMS cannot - so we send all alerts to the apps. In your case that alert #1173 is coming and going on a regular basis, but is probably nothing to worry about.
You can suppress these alerts by setting feature #14 to 8.
Regards, Mark.
Mark,
Regards, Mark.
Hey Markwj,
I have some feature suggestions for OVMS, and I would love to code some of them myself, but I'm having some trouble getting OVMS working succesfully off github in Eclipse with the most recent Android SDK. Do I need some additional libraries? Or would you prefer me just sending the feature suggestions/design and discussing it with you?
Since upgrading to iOS 8.1 (on iPhone 6), I have been unable to change any of the PARAMETERS from the Settings -> Control -> Parameters screen.
