Just checking if anyone else is having issues with OVMS at the moment. Mine has worked flawlessly, but now all of a sudden I'm just getting two green blinks and my app can't contact the car.
Yup I just checked the account right before you posted this reply. It had expired, which is weird since it shouldn't have hit the expiration date and still had a few bucks in it just a few days ago. I'll have to keep an eye on it I guess.
Jimmy, the same thing happened to me using H2O. I had to put my SIM card into an old phone, then go to their website, sign in and view my account. They sent me a text with an activation code. I bought some more minutes and put the SIM back into the module. It worked fine.Crap ok, time to investigate.
That looks a lot like the error I get when the passenger door is open with the key in the ignition. When the driver door is open, the message is spelled out.I tried doing a search and looking at the list of codes in the Github list but don't see it. Any idea what this alert from the OVMS to my iPhone app is? Thanks.
open vehicle alert TR2N/1173 (00002000)
I found this in the manual:
CHARGEMODE <mode> <current>
Sets the Charging Mode to one of: STANDARD, STORAGE, RANGE, or PERFORMANCE and sets the maximum charging current to <current>, an integer. This command can only be issued by the registered Phone.
I can change the charge mode successfully:
CHARGEMODE RANGE
CHARGEMODE STANDARD
But nothing happens if I add an integer
Firmware version: 2.6.5/TR/V2
samehere, integer is not taken into account e.g.
chargemode standard 13
Help! How can I get the OVMS to stop fighting against me when I want to change the charging settings from the car?
I have location based charging set for cool down and to open my garage door. But, sometimes I want to set range or performance mode charging. The OVMS often doesn't have service in my garage, so I have to change the charging settings manually. However, when I push the buttons on the display to change the charging settings, the OVMS just keeps changing them back to standard mode charge.
You say that your OVMS "often doesn't have service" in your garage.
When it DOES have service, send "ACC DISABLE", and you can override anything. When it DOESN'T have service, you will probably need to disconnect OVMS.
Can I program it to just charge at whatever setting the car is or was set to after cooldown is complete?
What if I set the ACC location to NOCHARGE, but with COOLDOWN enabled?
My OVMS is "down". It gives 3 sequences of 6 Green blinks, and the Green+Red for like 3 to 5 seconds.. And the starts the whole thing over... Any thoughts?
Speaking of cell reception, does anyone have any good ideas for upgraded cell antennas? My garage is just on the edge of reception . When the weather is good,it connects fine.But when it is cloudy it often doesn't connect.Sounds like it can't get a cellular lock (no reception).
A good starting point for troubleshooting is:
Support FAQ | Open Vehicles
Regards, Mark.
