I took my P3D+ to NCCAR in Garysburg, NC, for a HPDE with Out of Spec Motoring.
Mods:
My fastest lap was a 1:39.570. There was a lot left on the table but I only got in a total of 15 laps in so I was still trying to gauge the track and the limits of the car (I have not driven here before).
Consumption: 1,350-1,400 wh/mi; higher than I expected but there is a pretty long straight.
Takeaways:
Mods:
- Model S Calipers & Rotors w/ Hawk DTC-70 Track Pads
- APEX ARC-8 18x9.5" Wheels & 275/40/18 Nexen N Fera SUR4G Tires
- Motul RBF600 Brake Fluid
Takeaways:
- The Model 3 needs camber in a bad way. The edges of my tires, especially the fronts, were chewed up quite bad. That is definitely next on my priority list as I don't want to ruin new tires.
- The car is predictable, though I will say driving is a bit odd with so much regen, this is definitely a car where you steer with the throttle and you do not want to fully let off mid-corner (unless you would like to drift).
- Power becomes limited fairly quickly but (and here is the important bit) remains very consistent thereafter. Speed at the end of the front straight was consistently between 118-122. I found that the amount it limited power was also not very high, probably in the realm of 5% or so.
- It's quite capable on the track. As you can see in the video, a Ferrari 488GTB could not get away (now, given the right driver I am sure it could, but the point remains). I am looking forward to running some clean, dry laps at VIR.
- Overall, the Model 3 proves that EV's are track-capable vehicles and with the proper hardware (pads and tires mostly), and adequate charging capacity, you can have fun, go fast, and not burn gas. I bought the car for this exact purpose, and so far it is proving to be better than expected. Kudos to Tesla, the car is fantastic.
