@AnxietyRanger, as long as they leave my frunk alone I'd be happy
Are you talking about your car or...?
I did. He only mentioned that coolant connector is the same. Total heat load of P100D is higher than P90D. It is possible that existing P90D cooling system has spare capacity to handle the extra heat load, but we do not know if it does.
My point is that putting P100D pack in P90D might require additional modification/replacement of cooling system components that are outside the pack.
For what?
I do believe it is possible to upgrade the P85DL. Hope to get a real answer soon, as you suggest!
Thank you for contacting Tesla Motors. If you purchase the Ludicrous Retrofit now and then choose to upgrade your battery at a later date, you will not have to repurchase the Ludicrous Retrofit. If you were to perform both upgrades at this time, your vehicle should perform as well as a P90Dfrom the factory.
Thank you for contacting Tesla Customer Support. Regarding your question about upgrading your battery from P85D to 90kWh or 100kWh, unfortunately upgrading is not possible from your current battery to 90kWh or 100kWh. If you have any questions I invite you to contact your local Service Provider.
Thanks for contacting Tesla. Unfortunately the 90kWh battery retrofit is no longer available.
Do you seriously think that the current cooling system is even remotely reasonable? I can overheat this car in a matter of seconds. I cannot think of another car currently in production that is even close to that bad.
You can overheat the motor.. Not the battery..Do you seriously think that the current cooling system is even remotely reasonable? I can overheat this car in a matter of seconds. I cannot think of another car currently in production that is even close to that bad.
In fairness, wk057's post does suggest older models (P85/P85D/pre-facelifts?) would require changes in the connector area, but he seemed to suggest this is merely a small spare part swap.
Try to pack it up with dry ice.
I don't believe anyone has done a continuous rating on the battery, but thanks to Europe we have a continuous rating of 66kW for both motors. The discharge rate from the pack is well under 1C at this level. So yes, obviously the motor is the problem.
If someone could dig up the V5C or certificate of conformity on the P100D, that would be nice.
And perhaps most significantly for this conversation, there is already a Tesla Part Number for that part.
So to spell it out, why create a part number (and presumably a part) to make a battery pack backwards compatible if it isn't backwards compatible for some other reason?
I understand the arguments that there may be other differences, like cooling requirements and suspension issues. I'm not disagreeing with them. (I don't have the technical expertise to even consider disagreeing with them.) I'm merely asking why Tesla would create the part to make the pack backwards compatible if it isn't really backwards compatible.
Even if the first part is true, in no way does that mean the second part follows. Even at an acceptably low discharge rate, 2C, which can be done with no cooling at all, gives us 180-200kW output rate from 100% to 0%. This is more than the motors can put out. Plus, the cells are liquid cooled.I believe that 69kW is continuous rating for the performance rear motor only.
The maximum rating of the motors shown in the Manual is for 30 minutes. So while motors can be limiting for the racetrack use, limitation for going max power for shorter periods of time is in the battery.
Nailed it. Also, 100lb is not enough to need to tweak the suspension, not even close.Even if the first part is true, in no way does that mean the second part follows. Even at an acceptably low discharge rate, 2C, which can be done with no cooling at all, gives us 180-200kW output rate from 100% to 0%. This is more than the motors can put out. Plus, the cells are liquid cooled.
I hope Tesla will go the rest of the way and get us to a "win win" solution.
