Just keep in mind that the limit appears to be reducing 1600ish amps from the battery to 1500ish amps. NO P85DL was allowed 1600ish amps which tells me they will not experience a roll back (because we are already there).
Do keep in mind that Tesla made changes to the cooling AND battery interconnect with the 100 (likely among other changes). They apparently addressed the 1600ish problem and made a decision to NOT do a P85D to L style field upgrade. Given the distraction that program was/caused, I can understand why they would like to avoid it. They have also made a decision not to battery swap the problem away. The only option left is to determine just how much abuse the battery can take then cap its high amp use below that threshold.
Lastly, people keep writing about drive line weakness. This may be the case but, logically, all indications point to a battery weakness and nothing more. Ing speculated exactly the way I would have addressed the issue. Specifically, the first X time period is "free" in that the thermal inertia of the interconnects allow for a short period of high amperage use before deterioration begins (or skin charge in the cell allows for very short high C discharge without damage if it is a cell issue). If you exceed that time, a counter then tracks the exposure. Once the limit is reached, the 1600ish amp stress if removed forever. This is the most logical explanation. I think it is also worth noting that, if it is a cell issue, the counter would only function at higher SoCs while, if it is an interconnect issue, it should function all the time (1600ish is 1600ish without regard for the SoC).
The only way we are going to know is if someone throws the BMS code into IDA
