Tesla trading chart for Jan 19
NASDAQ chart for Jan 19
TSLA technical chart, including Jan 19
We knew last night that today was going to be good because the market historically reacts to Morgan Stanley upgrades or downgrades, and Adam Jonas moved his target up about $60 and went from neutral to buy rating. Thus, the stock was already above 245 when before-hours trading began. Many TMC members sought to understand the weak performance of TSLA after the early morning hours. Broader markets were down. Refer to illustration 2 and you will see a general correlation between TSLA trading and NASDAQ trading, with the exception that TSLA began the trading day much higher than it closed yesterday.
One possible explanation for the weak performance during mid-afternoon is that longs were taking some profits and de-risking somewhat after the significant climb. Volume exceeded 7M shares. Inauguration day tomorrow holds the possibility of producing some negative market moves if civil unrest becomes excessive, but if all goes fairly smoothly, there's also a chance for a collective sigh of relief and a broader market rally. Thus, the short term remains questionable, but the uptrend remains solid after today's action and it could weather several days of flat trading without falling outside its bounds.
The technical chart is interesting because you can see the 200 dma remains fairly flat at about 214, but TSLA continues heading up in its up channel. Notice that TSLA today went considerably above the upper bollinger band, which is a bullish indication, but then settled back into the upper end of the channel prior to close. If you study the technical chart, you will see that every time TSLA zoomed above the upper bollinger band, with few exceptions it settled back down into the channel before close. Those times it closed above the upper band it closed not far above. Keep this history in mind as you do your trading in future days.
Conditions:
* Dow down 72 (0.37%)
* NASDAQ down 16 (0.28%)
* TSLA 243.76, up 5.40 (2.27%)
* TSLA volume 7.7M shares
* Oil 51.39, up 0.31 (0.61%)
* Morning's Fidelity short share drawdown or (covering) and interest rate: ?
