Today was a strongly positive macro day as some solution to the China trade war looks possible. Not surprisingly, TSLA lagged behind the broader markets even though most tech stocks were up 4-5% today. A glance at the short percentage of trading gives you the answer: 67% of TSLA trading was done by shorts today. Interestingly, volume was up noticeably from last week at 8.4 million shares, but as more investors bought TSLA shares today, shorts chose to significantly ramp up their selling and other manipulations in order to minimize the damage. The NASDAQ did a bit of a dip at about 11:20am today, but shorts sold like crazy to bring about a dip on steroids. As TSLA approached the red/green line after 2 pm, shorts capped the stock and tried to walk it down slightly before losing control and TSLA ran up onto the green for its close.
With 67% of TSLA being traded by shorts today on a positive macro and positive Tesla news day, the manipulations reached levels that should qualify for some type of Olympic trophy.
Looking at the technical chart, you can see today's push well below the lower bb to 292ish, but without any real rationale for this drop, buyers stepped in and bid the stock back into the green. Looking at the previous excursions below the lower bb, you can see that in most cases TSLA then proceeded to rally and head towards the upper bb. The exception I see on the chart was in November when the recovery from 292.63 led to a mere 326.67 before revisiting the lower bb briefly at 300.00 (and then climbing above the upper bollinger band). If TSLA's behavior is typical, it will begin a climb after this bottoming out in the 290s. What is untypical about TSLA trading recently, though, is that shorts are continuing to throw all necessary resources at TSLA in order to trade two-thirds of the shares and influence TSLA's trajectory. As you can see, on days such as today the longs can overrule even this steep amount of manipulation by shorts, but the results are far less spectacular than what you'd see if manipulations by shorts weren't so intense. We also have another week to go before learning the Q1 delivery numbers (and, more importantly, the Model 3 production rate at month's end). As long as the production numbers aren't disappointing, I think TSLA will by then be heading back up to more reasonable valuations. I took the opportunity to acquire more TSLA today and hope you too had a chance to buy at this steep discount.Tesla might now rally or it may remain lethargic through the delivery report, at which time it will climb like a Falcon 9 rocket if the M3 production numbers are good. Better days lay ahead.
Conditions:
* Dow up 669 (2.84%)
* NASDAQ up 228 (3.26%)
* TSLA 304.18, up 2.64 (0.88%)
* TSLA volume 8.4M shares
* Oil 65.70, up 0.15 (0.23%)
