Resist
That's why they did it, to effect more drama to their story and deflect from the truth.I have to say the spreadout fingers is a nice touch. Very reminiscent of a 1950s horror movie
The most robust solution is to carry a glass breaker on you no matter the vehicle. For any emergency situation, you probably won’t want to deal with the 9v battery to save a few bucks.So, to prepare for this emergency should we all have 9V batteries in our pockets and a 12V jump starter in the frunk?
Good suggestion. Is there a space on the outside of the car to store this? Maybe inside the tow hook area? I guess you’d need one on the outside and one on the inside. Though with the new Li on low voltage batteries perhaps risk of getting locked out is not as high.The most robust solution is to carry a glass breaker on you no matter the vehicle. For any emergency situation, you probably won’t want to deal with the 9v battery to save a few bucks.
Don’t know. I prefer to keep it on me in case of needing to escape the vehicle too. Combo seat belt cutter/tempered glass breaker.Good suggestion. Is there a space on the outside of the car to store this? Maybe inside the tow hook area? I guess you’d need one on the outside and one on the inside. Though with the new Li on low voltage batteries perhaps risk of getting locked out is not as high.
People just store a small alkaline 12V or two or a 9V in a small zip lock bag in the tow hook area. Then have a small jump starter in the frunk. Many are dual/triple use and include a tire compressor and light, so is perfect as an emergency kit.Good suggestion. Is there a space on the outside of the car to store this? Maybe inside the tow hook area? I guess you’d need one on the outside and one on the inside. Though with the new Li on low voltage batteries perhaps risk of getting locked out is not as high.
A battery that does not get sleep turns into a sad battery.In theory if sentry mode is on, the car shouldn’t sleep so therefore wouldn't get locked out.![]()
Yes. Can have sentry exclude home, work, etc where you can have a jump pack (or 9v/12V battery to pop the frunk) readily available. But should reduce the risk of it dying somewhere random at an inopportune time.A battery that does not get sleep turns into a sad battery.
What? If sentry is active it doesn’t matter if the 12V dies. The car uses the HV to power everything when awake.Sooner or later the 12v is going to stop accepting a charge. When that happens the doors stay locked. That's probably going to happen quicker the more you use sentry.
Not a reason to avoid using sentry in sketchy locations. A good reason to stash a 9V in the bumper.
I'm pretty sure my dad's old 1982 Camaro had frameless windows and there was no drop the window function... it had manual cranks.Believe it or not, Tesla did not invent frameless car windows. They have existed for over 20 years. Amazingly, all the other automakers with frameless windows can still manage to drop the window even with a mechanical door release and without potential for glass damage for using the mechanical door release.
I didn't mean to imply sentry would get you locked out.What? If sentry is active it doesn’t matter if the 12V dies. The car uses the HV to power everything when awake.
But if the 12V dies you will not be able to open the doors after the car sleeps (eg at home if you disabled sentry at home).
Yes old school style was just simple pressure from closing the door against the seals.I'm pretty sure my dad's old 1982 Camaro had frameless windows and there was no drop the window function... it had manual cranks.
You can disable sentry mode in favorite places. Eg places where you’re probably going to park for long periods like home and work. Which are also places where you can easily keep a jump pack.I didn't mean to imply sentry would get you locked out.
Sleep gets you locked out. Sentry uses more battery. Little battery failure locks you out. Big battery lack of sleep slowly kills the big battery. It's a giant circle of death.
Best keep a 9v in the bumper and sleep where you can.
True. And based on your car, you may have laminated glass on side windows. (Mine is tempered.) Looks like newer teslas have tempered for rear side quarter glass and possibly laminated for other side windows.Glass breakers are less effective on double pane laminated glass, and some are not very effective on single pane glass. If you do get one, test it on a junkyard car to see if it works.
