Who has time for a work around or are even thinking about a work around when you have a Toddler in a Car Seat trapped in a Car when it is 90 degrees out?
Edited my original post so entire video plays,
Doubtful.Re: child trapped situation
Just a thought: While awaiting the arrival of emergency services, would someone with a coat hanger be able to pull the emergency release on the front door in this case? (Not in my car, as I said, I have access to that covered by a pocket bin tucked in there.)
That said, when was the last time you saw a wire coat hanger?!
Carrying the 9v taped to the outside of the car seems to be the best way to solve this without breaking a window, but again, I'm not sure I'd wait for that to happen if it was my grandkid; there'd be a broken window as fast as I (or someone else) could break it. Ironically, though, my window breaking tool is inside the car.
They should have made clear that this can happen to any vehicle with an electronic door lock. GM, Ford, Audi, BMW and others all have vehicles with electronic door locks. My local news station in MI at least made that point. But this one made it sound like a Tesla specific thing.
The electric latches are stupid no matter who makes it.They should have made clear that this can happen to any vehicle with an electronic door lock. GM, Ford, Audi, BMW and others all have vehicles with electronic door locks. My local news station in MI at least made that point. But this one made it sound like a Tesla specific thing.
It makes more sense that it would fail right after using energy - probably the last little bit it had (waking car up, booting up touchscreen, etc) than failing after using barely any energy after sleeping.Sure, but it’s pretty hard to accidentally lock yourself out with smart keys these days.
I don’t really get how these situations happened either. Locked OUT of the car after it’s been sitting and asleep, sure.
But being locked IN the car after having recently opened the door to get in is weird. The 12V had enough power to open the door initially which should have woken up the car and closed the HV contactors, thereby switching to the DC-DC converter to power all accessories from the HV battery. Unless it very coincidentally literally just had enough power to trip the door latch but not enough to flip the contactors and power the DC-DC converter.
When the 12V fails you have no power to the door locks. Smart key no good.Sure, but it’s pretty hard to accidentally lock yourself out with smart keys these days.
My Prius had that too. And a specific place to put the fob against the dash to start the car. The salesman demoed it when picked up the car and at 10 p.m. in an emptying church parking lot in -30*C temps, I was glad he had! In my case, it wasn't the 12V that went, it was just the battery on the fob so I could start the car and head home.Lincoln has a small key in the key fob that you can use to unlock the Car incase of power failure.
I used to have a 2018 Model 3 and if I remember correctly the window always lowered when using the manual release. It was a December 2018 so I wonder if the update happened earlier in the year because I do remember something about the owners manual saying using the emergency release could damage the window and I couldn't figure out why because my windows lowered when using it.The electronic latch lowers the window before popping the door so that you don't damage the window or the door seal. In a software update, Tesla also added the "lower the window" functionality upon opening with the manual release, however the operator still has the potential to cause damage if they're too quick to push the door open.
From the same news station, figures. You think they have it out for Tesla, hmmmm. And the woman freaked out even though her car was inside the garage out of the heat. She could have supplied power to the wires behind the tow hook cover, to open the frunk. Then jumped the 12v battery to open the doors. Problem solved. And had she called Tesla they would have gotten someone there to do it for her. But it's surprising she said the emergency responders said they can't get into Tesla's. Either they are incompetent or not trained about Tesla's. And again, this can happen to any vehicle with electric door latches, so for this new station to focus entirely on Tesla is biased and irresponsible reporting. I would bet this happens for frequently with ICE cars than Tesla's, just like with car fires.
I was proactively warned in my model S. Happened at 1.5 years old but has been fine 6 years since.The woman mentioned that Tesla should provide drivers a warning when the 12V battery is going bad. A couple of points about that:
1. I don't recall any of my previous ICE vehicles giving me such a warning. A driver would typically know that the 12V battery is going bad because of SYMPTOMS: slow cranking, dim headlights, 'phantom' warning lights, et cetera.
2. I thought Teslas DID give a warning when the 12V battery voltage is low.
3. Why would a Tesla owner expect a 12V battery to last the life of the car (i.e. not ever needing to be replaced) when one wouldn't have the same expectation of an ICE 12V battery? I mean, the physics isn't any different. Here in Florida, you typically get a good 2-3 years out of a battery (lead-acid). I believe Tesla recently switched to lithium-ion chemistry for their 12V batteries and you can always replace your lead-acid for a lithium-ion one if it didn't come with your particular vehicle (at your cost). However, lithium-ion doesn't last forever, either. Knowing that the cause of Tesla owners getting locked-out of their cars is usually due to their 12V batteries going bad, I proactively replace mine as part of my scheduled maintenance routine. I mean, they're not that expensive and it's well-worth the peace-of-mind knowing I won't be randomly locked-out at the most inconvenient time.
Joe
Makes me wonder why Tesla did not just use the same manual release design as the front doors for the rear doors.
Did you replace it yourself or did you have Tesla Service Center replace it? I ask because I'm wondering if Tesla replaced your battery with a lithium-ion one. If not, you're getting a good long stretch out of a lead-acid.I was proactively warned in my model S. Happened at 1.5 years old but has been fine 6 years since.
Tesla mobile replaced it in 2018 under warranty.Did you replace it yourself or did you have Tesla Service Center replace it? I ask because I'm wondering if Tesla replaced your battery with a lithium-ion one. If not, you're getting a good long stretch out of a lead-acid.
Joe
