I seen this on Blomberg first. I was reading trough the posts and this is a monster off-grid installation
. It seems you even purchased more battery modules than the initial pack.
I live OffGrid for not that long I will have two years this spring. I use LiFePO4 for a few reasons (excellent safety, lowest amortization cost, easy to find large capacity cells 1000Ah no problem)
On my small 65sqm (700sqft) OffGrid house I was concentrating on energy efficiency and reduced use so you may find my power consumption ridiculously small
(based on what I read here).
I have at the moment just 3x 240W PV panels and a 24V 100Ah LiFePO4 battery so 2.5kWh capacity. My average monthly power consumption is around 80kWh a bit smaller in November /December and usually around 80 to 90kWh the rest of the months.
On the positive side my system is extremely simple at least compared to this installation. All the electronics are inside the Solar BMS a device that I designed and build specifically for my house but is open source so "anyone" can build one.
I have now a new version on Kickstarter and this new SBMS will be able to handle a 3kW PV array and with a 400Ah battery or more it will be able to sustain about 300kWh/month extrapolating from my current data.
I will be curios what is your expected monthly power consumption?
I recently made some calculations related to amortization cost and should be about 16 cent/kWh most of this is related to battery amortization cost since that is the most expensive part.
I can give more details if someone is interested but since this forum is about Tesla I will limit my post to this.
