frisco
New Member
hopefully it's not overpriced or a lease model like solarcity.
A local college here in SW Florida recently installed a large solar setup using a 200kwh battery provided by Tesla. I asked how much they paid for the battery, and the response was "Hundreds of thousands of dollars." So I seriously doubt Tesla will be providing them at a reasonable cost (at least compared to the cost of salvage modules). I inquired with the stationary battery division of Tesla to see if I could buy a 100kwh stationary battery for a project I am working on, but they said they aren't available, so the college must have just been a test case.
- - - Updated - - -
- Battery capacity
- 36 modules from 2.25x Tesla 85kWh packs
- 191.25 kWh (DC side)
- ~4,200 Ah
- 43.2V nominal @ 3.6V per cell
- 15,984 cells (!)
- Inverter capacity (8x Outback Radian GS8048A)
- 240VAC @ 60Hz w/neutral
- 64kW continuous AC output
- 30 minute surge: 72kW
- 5 second surge: 96kW
- 100ms surge: 135.76kW
- Grid->Battery Charging Capacity: 57kW
- Expected AC output from pack after safe SoC window and efficiency considerations: ~160 kWh usable AC
- PV Capacity (In Progress)
- 102 Panels @ 435W (20% efficiency)
- 44,370 Watts DC
- Split into 17 sets of 6 panels (3 parallel of 2 in series)
- 17 individual MPPT charge controllers (Midnite Solar Classic 200)
As for cost, I'm going to actually keep that total to myself for the moment. It, admittedly, has gotten a bit out of hand, but it has been too awesome of a project not to see through to the end... budget be damned.
WK- To get a battery charging capacity of 57kw from the grid I'm assuming you're figuring you'll be charging at 50v x 115.5a x 8 inverters = 57kw?
