Ulmo
I COULD ask to park it in my parent's garage and have it connected to a standard 120V outlet, BUT both of my parent's cars are expensive cars which they OBVIOUSLY would PREFER to keep inside the garage. Additionally, my Dad is kinda crazy with energy conservation(EVERY SINGLE TV is on a power strip including the cable box and is immediately powered off when the TV is off) so I don't know how he would feel about the car being plugged in for 30 days!
- Set your car's charging schedule to start during cheapest electricity charging time. (If you have ample solar, you could alternatively set it to very low amps during peak excess sunlight, perfect for long term storage, especially since this will require the automatic battery BMS system to do less battery preconditioning to get it up to proper heat level. By very low amps, I mean super low, like 5 amps or so, to use only 600 watts; depends on battery age, but a 70kWh battery that depletes 2% every day could be recharged from 11AM to 2PM sunlight for 3 hours at 466 watts, so 4 amps is OK, whereas an older battery that loses 5% per day for a 85kWh would require 11AM to 3PM sunlight at 1000 watts which is about 8 or 9 amps; similar numbers at night, but you aren't worried about staying under excess solar use to avoid peak charges, but you do want to charge it fairly quickly to avoid having to keep the battery heated for as long while charging which uses more electricity).
- Of course, like discussed here already, set your charge level to 50%. (The day that is before the last charge scheduled charge before you expect to arrive home, you can remotely set your charge level higher if you expect to go futher than the 50% will allow.)
- Plug your UMC into a beefy exterior-rated extension cord (such as a 10AWG (usually listed as "10/3") 25 foot or even a 50 foot outdoor extension cord, available from Home Depot for over $100 for the longer variety) to a GFCI 120VAC 15amp or 20amp normal household outlet near to your parking spot that is the minimum comfortable length to reach out to your car in an inconspicuous location so no one tampers with it. Set your UMC to charge at 12 amps or less during this time; I think it will enforce this. This is really slow and not fast enough for daily commutes, but for just long term storage, I think it may be enough in most climates. Obviously, raise the connection between the beefy (10AWG is best) exterior rated extension cord and the UMC plug off the ground a bit so that water doesn't go in and trip it, and so that rain will drain away. Cover it with something that will keep rain off, too. Also, make sure the socket you plug into at the house is new and well installed with the circuit and screws well connected and no bad wiring, so it doesn't burn the house down in the middle of the night (electricians can verify that).
Ideally, your parking spot at your parents' will be within UMC distance of a qualified 15AMP or 20AMP GFCI outlet that is safe to use, so you wouldn't need an extension cord at all. Otherwise, see my buying list below for good extension cords.
- Regarding your dad being kind of crazy, that's an issue you will have to negotiate: I just told you the correct way to save your car. If you do not do that, you will potentially lose tens of thousands of dollars of battery prematurely, it will be your fault, and it is not covered by warranty; tell your dad that penny-pinching on one end to end up spending WAY MORE MONEY AND ELECTRICITY on the other end makes no damn sense. Then again, I don't get along well with a lot of people, so there's that ...
This is what you want for heavy duty extension cords for 120VAC 12amp: look for the 10/3 (which is rare but I will tell you where to get it; don't get 14/3 or not as bad but still not as good 12/3 (higher AWG is worse)), which will keep the resistence much lower, and the total amps used lower, and the total heating of the wiring in your house lower, and contact distortion and wear and tear lower, and much much safer (get the shortest one that makes sense on the end of your UMC which already has its own length); note that thieves love to steal these since they are great extension cords, so you need to hide these away from sight or awareness; note also that these are not suitable for daily commute charging of a Tesla, only for long term storage charging needs in climates that are not super-cold (or if you are a professional contractor, for running large compressors on the end of extension cords which is usually not possible with regular extension cords):
- Southwire 25 ft. 10/3 SJEO Outdoor Extension Cord with Lighted Plug-1787SW0002 - The Home Depot
- Southwire 50 ft. 10/3 SJEOW Outdoor Heavy-Duty T-Prene Extension Cord with Power Light Plug-17880002 - The Home Depot
- RIDGID 50 ft. 10/3 Heavy-Duty Contractor-Grade Indoor/Outdoor Extension Cord-HD#729-706 - The Home Depot
- Southwire 100 ft. 10/3 SJEO Outdoor Heavy-Duty T-Prene Extension Cord with Power Light Plug-017990002 - The Home Depot
- RIDGID 100 ft. 10/3 Extra Heavy-Duty Contractor-Grade Indoor/Outdoor Extension Cord-HD#866-886 - The Home Depot
