SuisseDriver
Given the exponential nature of resistance at higher speeds, and the range decreases that graph demonstrates, I'd suggest between 100-125 at 100 is more likely.
Again this is before any other factors. Do that trip in 20 degree weather, and you might have a 75 mile range car.
So you can continue to be of the opinion we don't need larger battery capacities in these scenarios however the evidence you are using to refute that doesn't support your arguments very well IMO.
I have a S75D and my father a S100D. The S100D has more or less exactly the same range as the Model III LR so we can compare them.
I have some experience on german Autobahn where I made a Lauterbourg (French border close To Kalrsruhe) to Pratteln SC which is a 200km trip. As was said, German Autobahn are not unlimited everywhere. So you still hit some 120km/h zone for bridge / exit. On the unlimited portion, I was between 180km/h and 227km/h (more or less the maximum speed I reached based on Waze on my smartphone) and I could easily made the 200km with less than 90% of the S75D battery.
Another way to look at it is that the calculation is showing a physical consumption need of 75kW at 200km/h. If we consider 83% for the total Model S powertrain efficiency, it means a need of 90kW.
In reality, this is what I experiences with the powermeter a little bit below 100kW so sustain this 200km/h speed.
It would mean that I could do 200km with 100kWh on the S100D. This means that you could do the same with the Model III LR (which has a 75kWh battery but has 89% efficiency and needs less power because has a better SCx).
In all practical purpose, even in Germany, because you do NOT have 200km straight, unlimited, without traffic, without working zone, without limited portion, a Model III LR or S100D can easily do 300km at a sustain high speed (>180-200km/h).
My experience on having driven both the S75D ~ Model III normal and S100D ~ Model III LR is that the S75D is very practical but requires a little bit of planning and has more constraints. The S100d (or Modell III LR) has just a range which is a no issue for anyone but the very most niche case. The range in normal situation is 450-500km and there is no situation where it can be a constraint as you would anyway stop at some point which such a range.
