h2ofun
Looks like you maxed it out?Ordered mid May (2021) and installed last week.
I added a couple more pictures to my original post. In my case the 8.16 kW size is estimated to meet 96% of my prior 12 months. I discussed with Tesla about oversizing it but ended up deciding this was sufficient. It’s a small north facing 2 story with no roof shade.Looks like you maxed it out?
Wow.... everyone in your neighborhood have solar?It is done!
8kW Tesla Solar + 2PW added to an existing 4kW SunPower system.
1 x PW+.
1 x PW2.
1 x Gateway.
24 x 340W Q.PEAK DUO-G6+.
Full house backup with 2 x AC. I originally wanted the PW mounted in the garage but there wasn’t enough room to walk mount side by side. They would have had to stack them on the floor. My least preferred option as the garage was already tight enough for two cars. So we moved them outside. Should be fine, they won’t get a ton of sun due to proximity of neighbors home/fence, and actually look pretty cool on the outside. May also help with any noise.
Asked for the existing 14-50 to be added into the backup, and for the new wall connector to be connected only to the main panel (to allow the car to charge via grid during super off-peak and not pull from the PW). They still need to wrap up the panel / PW wiring, and will return tomorrow to complete the job and test operation.
It’s a newer neighborhood (2019 build), in CA. So solar was mandated. Everyone started with a ~4kW sunpower (microinverter) system. $18k add on!Wow.... everyone in your neighborhood have solar?
Did you ask them to install a "new" 14-50 or car connector as part of the solar install? if so was it on your 01 or other pre-install drawing/document? I asked for it during the physical site assessment but didn't see anything in my 01
We were concerned about this possibility in 2019 and tweeted Elon about it. He replied instantly and said a feature would be added to prevent the Powerwalls from being drained.It’s a newer neighborhood (2019 build), in CA. So solar was mandated. Everyone started with a ~4kW sunpower (microinverter) system. $18k add on!
I asked to install a new (still in box) wall connector. The 14-50 was existing. The electrician was able to call into the hotline to approve adding another 60A breaker for the wall connector into the setup. He started adding it into the backed-up panel but then I asked for it instead to sit outside (so that it could avoid draining the PWs at night while charge the cars).
Still not 100% if this is the best way to go, need to do some additional reading.
In 2020, the Powerwall and vehicle software were updated and the Powerwalls will now coordinate with charging Teslas to prevent the Powerwalls from draining in the event of an outage. This works for both wall connectors and mobile connectors.
Vehicle Charging During Power Outage | Tesla Support
Powerwall now coordinates with Tesla vehicles during a power outage to charge your car without exceeding the energy and power capabilities of your Powerwall.www.tesla.com
It depends on how you have your Powerwalls configured as to whether or not they will be used at night. We want to be as self-powered as possible so we program ours so that we really only use grid power for a couple hours per day.What about while the grid is active? Will the power-walls be drained each night to charge the car? Or at least down to the reserve %?
We have super off peak from 12-6am. So would prefer to remaining/usable PW capacity in the mornings, 6-10am.
We had the same issue. Installed, paid but no PTO. I was told that the panel configuration changed during install which triggered a new design.So .. Tesla just pushed a new design to my account (with everything the same as far as I can tell), and is awaiting for me to accept.
Even though just yesterday they went ahead and installed all panels and powerwalls. No electrician today, so PW are still not connected... I also have not yet paid the down-payment on the loan and still have a clickable-cancel-order-button ... Hmmm
Interesting. Will see what they say tomorrow. I've accepted the new docs, and they then scheduled a 'maintenance visit' for tomorrow to complete the install.We had the same issue. Installed, paid but no PTO. I was told that the panel configuration changed during install which triggered a new design.
Any update on this?........I also have this new lovely warning on top of my order page. Will need to call in tomorrow. No clue what that could be. Perhaps because I upsized by 4kW after the initial loan approval? I assumed they would simply re-qualify me? Income is more than enough to float a 30k loan.
I called in, and the PA seemed to think it was not an issue. They pushed the warning back over to the credit department to 'fix things on their end'. He thought it might have something to do with my initial order being for 4kW + 2PW, which then triggered the permit/credit check. After those steps completed, I then requested adding another 4kW. It seems they did not go back out and authorize a loan on the now larger amount. So nothing firm, he just suggested the warning/issue would go away on its own...Any update on this?
Good!!.. Hope the lender doesn't give you problems with loan terms.I called in, and the PA seemed to think it was not an issue. They pushed the warning back over to the credit department to 'fix things on their end'. He thought it might have something to do with my initial order being for 4kW + 2PW, which then triggered the permit/credit check. After those steps completed, I then requested adding another 4kW. It seems they did not go back out and authorize a loan on the now larger amount. So nothing firm, he just suggested the warning/issue would go away on its own............
Looks like they fixed it!Good!!.. Hope the lender doesn't give you problems with loan terms.
I just got my system layout today and the detailed drawings after much delay. It is for a 50 panel - 17 kW - (4) powerwall system. It appears that it will use (2) Powerwall + with builtin inverters and (2) additional powerwalls, no separate Backup Gateway 2. Let me know if you need to see any other pages of the document. Any comments regarding the system would be appreciated. Thanks.
I also had to text re. the inspection tomorrow. The electrician let me know that they were still missing a few parts to complete the install. Emergency shut off button was missing something, so it is not yet installed. Then a internal plastic cover and plastic screws on the v2 gateway.
Apparently they’ve been low on parts for some time now, and installers have been taking what they need from the sealed part boxes
