Hey everyone first time posting and after reading countless threads I have finally decided to take the plunge. I am looking to install 2 power walls and pre wire for a 3rd unit during this project, as well as leave room for solar in the future. I am starting off with an Eaton MBED3042B200 meter main w/ 225 amp bus 200 amp service disconnect. Not sure if it is technically allowed based off of NEC regulations but my first thoughts are to route the wires from the load side of the main service disconnect to the PW Gateway and then back from Gateway to the distribution panel. The second leg of the gateway I would plan to setup a generation sub panel to support the Powerwall and future solar install of 7.6kW. Is this even possible with the style of all in one, or will I be forced to run a sub panel for critical loads?
