Forgot to ask earlier. I'm having a Powerwall installed tomorrow morning. Apparently two location options.
1. An unfinished storage area in the center of the basement next to the main electrical panel. This area is conditioned space, year-round temps probably range 65-75F.
2. An unfinished storage area under the suspended garage next to the electric meter & PV switch. This area is not conditioned with temp range probably 40-75F. It's mostly a concrete bunker with a small amount of wood framing at the walkout.
Space is not a concern in either location, can easily fit multiple Powerwalls, although starting with one due to cost. I like the center basement for temperature stability. I like the concrete bunker as it would be more fire-resistant should the Powerwall ever decide to melt itself down. It would be rare, if ever, for temp in bunker to get to freezing, but 40F would not be unusual during cold spells. Claimed operating temp is down to -4F. It occasionally gets to that outside, but don't think it would ever do that inside the bunker. At some point, there will be an EV car in the garage.
Any thoughts on location? Should I be considering potential Powerwall fire in the decision? Fire damage between the two locations would be significantly different. Thanks.
