Were you eligible for 30% federal tax credit for your powerwall though you are also charging from grid. What I heard is atleast 75% powerwall charging should be from Solar to be eligible for 30% tax credit.In August 2016 I had 9.8kW of solar and a Powerwall 1 installed. I can charge it from the grid or from my solar panels.
Sorry to ask questions in old thread. However, I have exact issue. I have existing solar system and want to add powerwall 2. However, the representative I talked to clearly, specifically told me that if I have solar system, I can't charge the powerwall from the grid. I simply don't get the reason. Basically, my solar system generation can't sustain all the house usage, especially in winter. I have to charge from grid at night time and use them at peak rate hours. Also, my solar system use micro inverter and feed the AC back. Why can't powerwall pretend there is no solar system and charge from grid.
Powerwall is designed to qualify for the Federal Investment Tax Credit (ITC) when it is installed on an existing or new solar system and is charged 100% with solar energy. It does not qualify when installed without solar or if solar is installed after Powerwall. You should always consult your tax professional for your situation.
This is common. My Powerwall system bounces off the Reserve daily in the Winter due to generation less than the Peak period usage.75% threshold is for commercial applications. It has to be 100% for ITC on residential applications.
This means some people (with small, inefficient PV systems) may not have a fully charged battery during the day in the winter months.
It's a mysterious Tesla-only limitation. You could move CTs around to make Tesla think Grid = Solar, at your own responsibility.Sorry to ask questions in old thread. However, I have exact issue. I have existing solar system and want to add powerwall 2. However, the representative I talked to clearly, specifically told me that if I have solar system, I can't charge the powerwall from the grid. I simply don't get the reason. Basically, my solar system generation can't sustain all the house usage, especially in winter. I have to charge from grid at night time and use them at peak rate hours. Also, my solar system use micro inverter and feed the AC back. Why can't powerwall pretend there is no solar system and charge from grid.
You didn't say where you are located or what your utility billing policies and rates are. Whether you can save any money using Time Based Control with solar on a Powerwall depends completely on how your utility does billing. We can't help you decide without that information.Hi there. I've been reading the threads and I find myself in the same predicament. I have an existing solar system and I was looking into getting the Tesla powerwall. but now my fear is that if I get to power wall I'll actually may increase my yearly true because I will not be able to leverage my time of use. Looking at it at a economical view I'm starting to think perhaps it does not make any sense for me. Am I assuming correctly?
I think having the battery would almost be like going back to net metering in a sentence. A kilowatt for a kilowatt however you would get stuck paying to charge the car at night.
My biggest reason for looking into power wall was due to power going out 5 to 10 days a year. But at this point I'm starting to think a generator for the few days the power's out would be a more economical approach. Thanks for your time.
I also have a small solar system, not even double your size, but I have two Powerwalls. Last Winter, basically mid-November to mid-February, I was bouncing off the Reserve every day. This year is pretty much the same. While I would love to be able to shift Off-Peak energy from the grid so that I did not consume any Peak power in the Winter, that's just not how it works and I have to accept that I have to pay more during these Winter months. More because I don't generate enough and more because there is consumption during Peak hours. C'est La Vie.I'm a new Powerwall 2 user, and I have a tiny solar system - only enough roof exposed to sun for 2.4kW, and partly shaded too. I wish I found this thread before getting the Powerwall! As it stands, it's sitting at the backup limit, and not charging at all. I guess that will change when the days get longer and there's less rain - I'm in the bay area of CA, so guessing I'll get above 50% sometime in AprilMy solar system only made about 1kWh/day the last week.
can you raise the reserve to an arbitrary percentage?
All we know is that if you take the ITC credit, then it's a 5 year limitation that Tesla activates in their config on your Powerwall Gateway. What happens after 5 years, we can only speculate.Has anyone heard anything official from Tesla about this? Is the Powerwall locked to only charging via solar for the life of the serial number, or at some point will Tesla unlock them and allow grid charging if you buy them in conjunction with solar? Seems crazy that in 10 years they'd still be locked to solar only.
