I could have sworn that I read sometime last year or so, that the app got updated with the ability to initiate preconditioning of the car&battery via the app. I have yet to see this functionality. Was it ever rolled out for anyone?
Use that everyday up in Minnesota lolAlso, if you just want to turn it on (car heat and preconditioning) as opposed to scheduling, just click here
But isn't there a way to precondition the battery that doesn't involve heating/conditioning the cabin?Also, if you just want to turn it on (car heat and preconditioning) as opposed to scheduling, just click here
I don't see anything called "schedule" in my app (I have a 2017 Model S 75 so app is probably different).It is under Schedule in my App for 2020 LR
Yes - indirectly. Select scheduled departure, set you departure time, leave precondition off, enable off-peak charge and set the off-peak end time to be the same as your departure time. The car will start charging, so it is charged to your request value, at your deparutre time. Charging tha battery warms it, so the battery will be warm (or warmish) when you depart.But isn't there a way to precondition the battery that doesn't involve heating/conditioning the cabin?
Check to ensure your app is up to date, the current version is 4.5.1 (tap the icon at the top right, then scroll to the bottom to see the version number)I don't see anything called "schedule" in my app (I have a 2017 Model S 75 so app is probably different).
Was hoping to be able to condition the battery without being plugged in.Yes - indirectly. Select scheduled departure, set you departure time, leave precondition off, enable off-peak charge and set the off-peak end time to be the same as your departure time. The car will start charging, so it is charged to your request value, at your deparutre time. Charging tha battery warms it, so the battery will be warm (or warmish) when you depart.
That's the version I have: 4.5.1-864Check to ensure your app is up to date, the current version is 4.5.1 (tap the icon at the top right, then scroll to the bottom to see the version number)
You do not need to be plugged in to see schedule, but your car may not support these settings from the app. See if you can do it in the car.That's the version I have: 4.5.1-864
Perhaps I need to be plugged in to see the schedule option...
I am sure the car will protect itself, but I time my charging at the cold part of the night, so the charging can help warm the battery. I am very cautious. I still think it is best not to go all out on a really cold morning, having the car protect itself from your punishment. Best to let it warm up some to not push any components or the battery, but I am trying to be very protective for longevity.@DerbyDave, you don't need to refrain from pushing the car hard on an EV, or at least on a Tesla. The car throttles the available power for you. It's pretty clear when you look at ScanMyTesla. With a very cold battery (-16C) I've seen my max output power at 86kW, which is around 100hp maximum. The car was sluggish as hell even with my foot to the floor. That power value went up as I drove. As a reference, it can get to 400kW (or more?) on my LR AWD with boost.
I thought the main idea of preconditioning is to improve the car's capabilities on a cold morning. In particular, regenerative braking is essentially nil anytime the battery has been exposed to temperatures below a certain point for several hours (during a workday or overnight, e.g.). Reduced regen braking is not only inefficient, but can be dangerous, especially if the driver is not expecting reduced regen.The purpose is to precondition the battery not using the battery as energy to do this. Your battery will condition and warm as you drive. Just as in a normal car, don't push it to hard until the battery has had time to warm a bit. Best to have it plugged in. As ATPMSD says, you can precondition by enabling the interior heating on without plugging in if you are worried about getting snowflake warning.
