Unless tesla moves to superconductors as the charging cable the anything higher than 150Kw will require super thick cable at 400V.
The V3 SuC cable will be liquid-cooled, so the bottleneck shifts to the car's uncooled internal wiring, where P = I^2*R gives the heat loss.
The MS/X cables are of copper, whereas M3's are of aluminium, a material with 58% higher resistivity, thus need to be thicker to handle the same load.
It is unclear what max current the MS/X cables can handle, but if same as M3 then the battery/cooling comes into question. M3 has several parallel coolant flows whereas MS/X has a single ribbon contacting all cells.
My guess is the 100D pack should manage ~185kW.
