problem with scheduling precondition
I don't precondition for a set departure time every morning, but on occasion (depending on where I am and the weather) I want to do it -- but I find it hard to get the app scheduling right. Sometimes I roll the numbers to set the correct time (eg 09:45), and it reverts to the last time I used for preconditioning (17:00), even though it was weeks ago. Sometimes I turn it off after it' preconditioned that day, but it turns itself back on and preconditions to that time every day. Sometimes the wheel time just seems to slip (?) so I think I set it for 09:45, but when I pick up my phone 10 minutes later, it's set for 09:00 for some reason.
Any idea what's going on? Am I doing it wrong.? Can I fix this? I've got an iPhone SE(2) using iOS 15.1, and software version 36.5,5
Preconditioning is location based.
If you set a time to precondition at home for 6:00 AM and then set a precondition at a relatives house while you are visiting for the weekend at 8:00 AM, when you go home it will use the home location precondition settings of 6:00 AM. Same thing with turning it off or on. If you had it turned on at home, leave for the weekend and turn it on at your weekend location... then turn it off before you start your drive home you will find that it is still turned on at your home location even though you "turned it off" when you left your weekend location to return home.
Keith
Reactions: impastu
So how can I turn it off? I don't precondition every day (mostly because I don't plug it in at night), and althugh I often precondition before I leave work, I only work part time and I don't always leave at the same time.
Does this variability mean that I can't use the preconditioning feature?
MY-user
MYLR, 5s, OD9/10, received on Nov. 29.
Sep 15, 2021
337
241
Colorado
You can use the feature but, unfortunately, you would need to manually set it up each time. Tesla schedule is very primitive. It only has an option to do all days or only week days.
Reactions: impastu
jcanoe
6,707
7,568
Maryland
You can use the Scheduled Departure Charging feature and the Tesla Model Y will always complete charging by the scheduled time each day. Scheduled Departure Preconditioning is a separate, related function that can be set for week days only or all week. If you decide to turn off Scheduled Departure Preconditioning you need to turn off all the Scheduled Departure settings by toggling Off the Scheduled Departure button at the bottom of the Tesla Charging Screen.
There is also Scheduled Charging; Scheduled Charging is easier to understand. You just pick a time each day when you want the Tesla Model Y to start charging, not concerned with when charging is completed. You can't use both Scheduled Charging and Scheduled Departure Charging, you can use one or the other option.
Scheduled Preconditioning now supports location based Preconditioning. It is possible to set a time in the A.M. to precondition before leaving home from the Tesla Charging screen. You can separately use the Tesla phone app charging settings to set a second preconditioning time specific to your work location for the P.M. when you leave work.
If you don't follow the same schedule each day then the best option is to just manually start to precondition 10 minutes before you drive.
Reactions: impastu
Point taken; You should be able to turn off Scheduled Departure Preconditioning from the Climate Control screen inside the Tesla vehicle.
I have an issue where the car continues to "heat up" despite the fact that I have turned the pre-conditioning off. Ex. Thursday I set the car to pre-condition by 9am. When I left that day - I turned the preconditioning toggle off. Friday, Saturday and now Sunday, the car has continued to precondition by 9 am despite not having it turned on....
jcanoe
6,707
7,568
Maryland
Check the Climate Control, Preconditioning settings in the Tesla app on your phone, also any other phones that have the Tesla app installed and access to your Tesla Model Y.
