eprosenx
HI all,
Glad I found this forum. I too have a melted outlet. I had a licensed electrician install this years ago. Didn't have any issues until recently. We reach the cord about 10 feet to plug into the car, so I believe that over time, the plug started to wiggle out of the outlet, and/or weakened the contacts inside the outlet with the sideways torque that just the weight of the cord was putting on it. When I noticed it, the plug was slightly out of outlet. Sometimes the cord gets a little tangled and it's likely that we added some torque pulling on it. As you can see from the pictures, this was a close call. The breaker never tripped and the car gave no indication that there was something wrong. I leave the cable plugged in 100% of the time. Since we bought the car years ago, I'll assume that I have the gen 1 UMC.
I'll be making sure that I have a GFCI breaker and the recommended brand of connector this time. Replacing the box too with a properly mounted box. Will probably buy a new UMC too, just to be safe.
Wow! I am glad you and your family are OK!
Can you post pictures or confirm that you have a UMC gen 1?
That wire looks like 8 awg copper to me which is not rated for 50 amps (40a continuous) if it is romex (NM) cable. If indeed it is 8awg romex and you are using a UMC gen 1 then the electrician is at fault as they used the wrong wire (this would be a compliant install if you had a UMC Gen 2 since it is limited to 32a continuous it is ok on a 40a circuit which 8awg NM cable is fine for).
Also, please post what size breaker was installed (photos preferred).
