Someone was correct!I'm hoping the iPhone 8 (10th anniversary one) has wireless charing
Loved The Office references...I just did the wireless charger install in my S for the iPhone 8 plus... works great! This was the most helpful guide I found, and it made for a perfectly clean stock look.
Were you able to fit the board and charging pad altogether in the flip panel? Or just the pad and relocated the control board elsewhere? I'm afraid I'll end up with a charger too thick or with too short of wires!
Would this fit?
https://www.amazon.com/Aobiny-charg...id=1510424286&sr=8-17&keywords=3+coil+charger
Also can you close your console cover where you installed the qi charger
Yeah, I had to do the same, more or less as high as it will go without getting too close to the camera. To date I've tried 7 options for inside the car, many of which are compatible with our existing phone mount but none have offered a great experience. Still searching. Here's where I have my disk:Minor technical note for those folks who use a magnetic phone mount (like this one Magnetic Phone Holder (Slimline))...
In CA we are required to keep our phones on some kind of mount (not hand held). I have this mount in both of our S, and we have used them with our iPhone 7s. The new iPhone 8 & X have Qi charging (...Apple catching up). If you mount the thin metallic adhesive plate to the center of the back side of your new phone, you will interfere with wireless charging. So I had to change the location of the thin adhesive disc to the upper end of the back of my new iPhone X.
And a final further note, I actually stick the disk to the inside of the case I'm using, rather than to the back of the phone, the pic was just to show positioning
No. It does if it's nearer the center though.Those using metal disks on the back of the iphone X, even moved towards the top, does it get hot when you use wireless charging?
Aaah, look at all that lovely open space....I miss that!Everyone here seems to be very compulsive and is going to extreme lengths to implement wireless charging. I, OTOH, am lazy and of the KISS persuasion.
I just bought two QI chargers (one for me and one for my wife) and set them flat on the floor of the center console.
This works great and is easy. No fiddling. Just set the phone down and just pick it up. Always stays in place.
Installation time... about one minuteView attachment 259948
So... I did it!
It was not easy for me, and I had a couple of hiccups along the way, but the final solution works well -- an identical design to that of the OP. I had hoped that the wireless charging would work through my phone case, but unfortunately it does not. It did work reliably in the case when I tested it inside, probably because the plug in charger was of higher amperage than the USB port in the car. Oh well, so the case is gone now and the S7 Edge looks sexier naked... as long as I don't drop it!
View attachment 210458 View attachment 210460 View attachment 210463 View attachment 210462
