I think we are pretty close to agreement on the values to use for the LCA comparison of an ECO Prius and a BMW i3, so here are the calcs:
Prius
LCA CO2 for petrol is 24 lbs/US_gallon, equal to 40 kWh source energy
That works out to 24/56, = 0.429 lbs CO2 per mile or 195 grams per mile.
i3
Using the 2011 GREET publication by Wang et al,
I eyeball the 20 year NGCC Conventional gas at 825 grams/kWh
0.27 of that per mile in an i3, thus 222 grams CO2 per mile.
Shale gas is lower, and IIRC is about 15 - 20% of NG stock
I'm feeling lazy, so I'll guesstimate 800 grams/kWh weighted --
then 800*0.27 = 216 grams CO2/mile,
but divide by 0.94 to account for T&D losses, so 230 grams/mile
To some degree. I don't think we would use any peaking plants to charge EVs, and so on, but 45% versus 48% isn't a huge difference at the end of the day.
The interesting thing is that the GHG emissions are largely a function of the time frame/Methane's GWP. At 20-years, a Prius Eco/i3 are pretty close, but at 100 years the i3 is better, and difference approaches the ratio of Carbon emissions after a few hundred years. Since fugitive methane emissions are what gets the i3 close to the Prius, I wonder how much lower the 20-year GHG emissions would be if electricity was generated on site.
The fueleconomy.gov figures for Prius Carbon emissions per mile are correct, and apparently unrelated to the two (33.7kWh/gallon and 36.6kWh/gallon) energy figures we're seeing for gasoline. The EPA and other sources use 33.7kWh/gallon, the lower heating value of gasoline, because ICEs dump any vaporized water out the exhaust, and can't capture any of that energy to do work. The HHV of gasoline is 36.6kWh and represents the total energy available if all the combustion products return to pre-combustion temperatures, which is what we need to use for a net energy comparison. As far as I understand it, measurement of utility scale FF electricity generation uses the HHV, not the LHV. ICEs only use LHV because it's impossible for them to capture the energy that went into vaporizing water.
Combined cycle - Wikipedia, the free encyclopedia
I'm not sure why EPA estimates upstream GHG emissions as ~20% while CMU estimates ~25%. It's not going to influence the net much, since that's ~13 miles instead of ~16 miles. It could be some differences between GREET 1.7 and 1.8, or some differences in the assumptions. Without the specifics of both models, I'm not sure which one is more accurate.
Anyhow, the basic idea is that any claims about not being able to handle the generation requirements of EVs are just attempts to spread FUD. An EV that displaces a gallon of HC fuel frees up enough natural gas to generate some and maybe in some case all of the energy required to power it.
I've been a (3) for years so I'll describe the position: EVs are an appliance, in the general sense that they do not produce or save emissions. So cleaning up the grid first is the priority. To the extent that people buy EVs with their own money -- by all means. But tax money should be spent on grid infrastructure to facilitate wind and PV growth.
I've only really changed my tune because the country cannot see fit to stop the subsidising , and begin the taxing of externalities, of fossil fuels. Meaning I'll take the EV incentive and spend it on PV. Not efficient, but I don't make the rules.
Well, part of what's limiting grid penetration of renewables is their inability to strictly substitute for dispatchable generation. One of the ways to get around that is through less expensive, longer lasting batteries to store inexpensive renewable generation. And one of the ways to get less expensive, longer lasting batteries is to subsidize EVs.
We can dump all existing incentives into whatever the least expensive Carbon cutting measure there is, which at this point probably isn't EVs or renewable generation (I'm thinking tax credits for insulation?), but if we only extend tax credits to the least expensive Carbon cutting measure, then there likely will be little to no improvement in other Carbon cutting measures. My WAG is that subsidies are designed to minimize overall Carbon emissions by investing in many different technologies that can benefit from additional research/testing/mass production. We could only provide tax credits for the most effective form of reducing Carbon emissions, but that's minimizing the cost of cutting emissions, not maximizing the cut in emissions.
