Canuck
Thanks!
I wanted to see the plug end but I'm guessing you just wired in a male 14/50 plug on it. Correct?
That's what I did:
Thanks!
May I ask what your reasoning is for having 2 UMCs?
Before I bought my car I was considering the same (not wanting to be left stranded anywhere), but after 21 months and 50k miles and a few road trips, I've never found a need to use the UMC outside of my garage.
They have a switch because it is required under the NEC. Charging stations with >60A rating or >150V line-to-ground require a lockable disconnect:Here is the setup at my local Tesla Service Center... they have an ON/OFF switch inline with the HPWC.
I think I would do this even if I had a 14/50 plug.
Is a disconnect switch needed or can you just leave the UMC plugged in with current running through it all the time? I have read that these outlets aren't really designed for continuous plugging/unplugging and I don't think my wife could actually unplug the cord anyway. She has real small hands.
I don't have dual chargers so I am not interested in the HPWC. Plus the install is twice as much and the charger is $100 more expensive. Finally, I like the idea of having a backup UMC just in case something malfunctions.
Here's my question....I have 50amp wore pulled to a 14-50 nema plug. Can I haev 100amp wire pulled to my nema plug then hook up my HPWC to that nema plug?
Not sure I understand......you *can* run #3 THHN to your existing 14-50 receptacle, however, you can NOT "pull" more than 40A continuous through that 50A rated 14-50 device.
