Does anyone have some good data on the amount of range loss for 2-3 bikes on a trailer hitch for a Model X. Thinking of an extended road trip this summer, but not sure if the range loss is worth taking the bikes.
I believe that max weight is 120# per the manualThe Tesla trailer hitch on the MX is rated for 500 pounds tongue weight when pulling a trailer, so if you have the factory hitch, you should be able to hang the max number of bikes on it that it will hold. I too only haul my one bike and don't see a lot of range loss.
You’re both right. Tongue weight of trailer is 500lbs on 20” wheels. But that doesn’t translate directly to the bike rack. With a bike rack, the limit is reduced to 120lbs.
Damn, I was hoping to be wrong
Interestingly, the Model Y weight limit is 160 pounds.
"The hitch receiver is designed to support vertical loads up to 160 lbs (72 kg). When carrying bicycles, skis, or other items on the Model Y hitch, always check to ensure that the maximum weight is not exceeded."
OK, it is correct that the MX hitch receiver is designed to support only vertical loads up to 120 lbs. From my manual: "The hitch receiver is designed to support vertical loads of up to 120 lbs (54 kg). When carrying bicycles or other items on the Model X hitch, always check to ensure that the maximum weight is not exceeded. When calculating weight, remember to include the weight of the accessory carrier. For example, assuming the carrier weighs 40 lbs, the weight threshold is sufficient for carrying two bicycles weighing approximately 40 lbs each, or four bicycles weighing approximately 20 lbs each."
I guess I need to get someone to talk me through the physics that says a hitch that can take up to 500 lbs tongue weight (which is vertical weight) cannot also support, let's say, 200 lbs of vertical weight when the weight is not trailer tongue weight. What's the difference to the hitch receiver? Not being a smarta** - seriously just trying to understand the difference.
I use a Kuat Sherpa 2.0 Rack with 2 full suspension MTBs on board and see very little impact on range (Still believe <10%)
Also, for people stating vertical weight limits, I have a 5 bike rack coming in that is 85lbs and will consistently be putting 3-4 bikes on (30-33lbs each). I feel pretty confident the MX will be fine. There's a guy on YouTube using a 6 bike Northshore Rack on his MX as well.
Wow, six bikes! That makes me feel better about my 3 bikes. I imagine the load limits are conservative... at least I hope they are!
How do you guys handle the constant radar and parking alerts due to the rack (with and without bikes)? I get notified way to often and reversing is a pain due to the alert, even though I can see clearly out the camera and its not an actual problem to park.
Also need to be very careful with Bike Racks on the back in Supercharger stalls, I have a 2 bike Kuat and it can be challenging to get close enough for the short Supercharger cables.How do you guys handle the constant radar and parking alerts due to the rack (with and without bikes)? I get notified way to often and reversing is a pain due to the alert, even though I can see clearly out the camera and its not an actual problem to park.
The difference is the moment arm. The trailer tongue weight of up to 500 lbs has wheel support under the trailer, behind the hitch. That tongue weight pushes down more or less straight on the end of the hitch receiver because of how trailers are axled and because it's connected to a ball. The ball allows the connection to pivot without transferring torsion forces to the hitch receiver. Meanwhile, a cargo tray or hitch mounted bike carrier will have its center of weight well behind the hitch connection point. It doesn't connect with a ball. So every bounce and jiggle transfers a lot of torque into the hitch receiver.I guess I need to get someone to talk me through the physics that says a hitch that can take up to 500 lbs tongue weight (which is vertical weight) cannot also support, let's say, 200 lbs of vertical weight when the weight is not trailer tongue weight. What's the difference to the hitch receiver?
