I also charge at 60 amps. Everything stays nice and cool. Charges at 45 mph at that setting.
now we need to find info about that runs each on board charger at 30a or if one runs at 40 and the other at 20.
The battery capacity should be the same.e. Some of its capacity will, however, be used to isolate it from the ambient temperature.Hmmm, so we can see our rated capacity go up and down based on the time of the year?
I remember reading somewhere that anything over 40A was split evenly between the two chargers (30A each in this example). Hopefully someone can jump in that knows for sure.
I just plugged in my car for the evening, and paid attention to what it did. Charge rate set to 60 amps. Rate slowly ramped up to 30, paused there for what seemed to be about 10 seconds, and then started ramping up again until it reached 60 and stabilized there. Exactly as Cottonwood suggested. I agree with him that this likely represents the load balancing taking place between the two chargers.
Data point:
My car is 23 months old, with 19,278 miles on it.
February 2013 range charge: 257 miles
Today range charge: 257 miles.
Type B battery.
I generally charge to 80% full.
thats amazing. Zero degradation.
I have 43k miles on my 60kwh. I've lost ~10 miles of rated range. Not complaining. Was 208 new. Now 198
Along with that, I have found since I stopped charging at full 40 amps every night, I also stopped eating up UMC's. I think they couldn't handle the heat build up day after day. Current UMC is going strong. Usually 30 amps or less. Only if I need range as quick as possible do I use 40 amps now.
I have range charged two times in this past week after not range charging for months. The first time it was 254 but when I drove away I drove for more than 5 miles before it came down to 253. The next day I range charged and it stopped at 255 and I got the same kind of response. Typically when not on a range charge when I pull away from the SC my range drops within the first mile.I range charged yesterday and only got 247 miles rated which was pretty disappointing considering the last time I did a range charge I had 257 rated. I'm only at 25k miles on a B pack. Hopefully I'm just out of balance or the rated # is dropping due to changes in firmware calculations
Same here. I just set it at 30 and forget it. Plenty of time yo get the overnight charge I need for my next trip to work. Just a shame the chargers that Tesla provides can't reliably withstand continued use at the top if their rated range
