Power of the motors is directly related to the maximum speed the vehicle can attain (when friction losses, especially air drag, reaches maximum vehicle power). The motor is never putting out its maximum power until the vehicle can no longer be made to go faster.
Torque of the motors is the determining factor to how fast you can accelerate. Torque applies the force at the wheels that both accelerates the vehicle and overcomes drag force—up until the vehicle reaches its maximum power.
Any power (hp or kW) rating of the car determined by an acceleration test (e.g. 0-60, or 1/4 mile) is merely an estimate of the power available based upon some assumed relationship between power and torque. One cannot directly measure the horsepower limit of a vehicle except by reaching its limit.
I do not have a Dragy unit but PowerTools provides speed directly from the vehicle together with a time stamp. I need to repeat my 0-60 run when I get a chance to get an accurate new 0-60 time but suffice to say my car was barely faster than a dual motor long range Model 3 carrying about 250 lbs more in a side-by-side drag race over the weekend. PowerTools did not work for that run. My SOC was slightly higher 83 vs 80. I sensed three stages to the run. There was some front wheel spin from the Raven initially, then I caught up and then the Model 3 accelerated just as fast while I was pulling away steadily at an estimated (from the video) 2 mph.What are your Dragy results? That's all that matters.
It is - but this question was specifically asked about a non Performance Long Range Raven, so Ludicrous mode isn't on either of the car's being compared.
Which unfortunately means neither car has the L+ stats page available, where you can see the battery, front motor, and rear motor instant and maximum power usage and the current and maximum acceleration numbers that would make it easy to answer this question.
I am sure that all of the power numbers being pulled from the API are on the electric side, so a high efficiency motor will be delivering more torque for the same apparent electric consumption.
Get Dragy.I do not have a Dragy unit but PowerTools provides speed directly from the vehicle together with a time stamp. I need to repeat my 0-60 run when I get a chance to get an accurate new 0-60 time but suffice to say my car was barely faster than a dual motor long range Model 3 carrying about 250 lbs more in a side-by-side drag race over the weekend. PowerTools did not work for that run. My SOC was slightly higher 83 vs 80. I sensed three stages to the run. There was some front wheel spin from the Raven initially, then I caught up and then the Model 3 accelerated just as fast while I was pulling away steadily at an estimated (from the video) 2 mph.
Agreed, but my understanding is that the majority of the power during hard acceleration is coming from the rear unit so the overall efficiency gains would be reduced by a certain amount. Does anyone know the new torque ratio with the latest software update? If we knew that, I could more accurately compare Raven and Non-Raven power values to determine any differences.
Power of the motors is directly related to the maximum speed the vehicle can attain (when friction losses, especially air drag, reaches maximum vehicle power). The motor is never putting out its maximum power until the vehicle can no longer be made to go faster....
As @Saghost has pointed out, I was mistaken in what I said.A modern electric motor typically has a torque limit and a power limit - normally it puts out a fairly constant torque until it hits the power limit, and a slowly declining nearly constant power above that limit.
Most Teslas hit the power limits in the 50 mph neighborhood...
According to PowerTools the HP is a measure of the motor power and not the power drawn from the battery. I measured only 505 HP max. (375kW) fresh from the SuperCharger today at 80% SOC. Max. occurred at 54 mph. Peak was way below what I was achieving with my 100D. The acceleration was around 4.5 seconds 0-60 (without the 1 ft rollout removed). Anyone else experiencing below spec performance from their brand new Raven?
Do you have something to substantiate this claim? It does not fit with what I think that I know.since PowerTools draws it's speed data from the rotational speed of the wheels
I was able to record a 0-60 hard acceleration run this morning after installing 2019.32.1 last night.
Below is the graph generated from this morning's PowerTools file followed by the 100D result. Exact same section of road. Peak power today was 489HP @ 54 MPH vs 533 HP @ 60% from the 100D. What's noticeable to me are the high 10 and 19 mph data points, indicating tire slippage, since PowerTools draws it's speed data from the rotational speed of the wheels as opposed to GPS - slippage that I did not see in my 100D. Could this be due to new, better rolling resistance tires, hence Tesla's attempt at improving "driving dynamics during hard acceleration" in their latest software update? Has anyone else noticed this? Do Performance Ravens see this? Acceleration between 40 and 60 mph for my non-Raven looks and indeed felt faster.
View attachment 450402 View attachment 450403
I think I mentioned earlier in this thread that I’m noticing tires slipping at 0-5mph and again later on (Raven Long Range). I don’t feel like spending the money on new tires, but when I ran Pilot Sport A/S3s on my P3D I never noticed a slip.
Service Center acknowledges there is a problem with my car (could this be a Raven-wide issue?) and has escalated the case to Engineering. I'll update everyone when I learn more if it's resolved through updates. I'm really curious to know if any others are experiencing severe loss of traction immediately upon hard acceleration.
That’s great news! 32.2.1 hasn’t been pushed to my car yet. Can’t wait to try. I’m traveling so won’t be able to confirm it works for me too before the end of the week.I received an incremental update last night. 32.2.1.
I can’t get the tires to slip. Huge change. 5 attempts, no slip...
Yes, indeed. I think this data is, according to the following thread, most likely from rotation sensors with GPS-based correction over time to adjust for tire wear etc: Speedometer accuracy | TeslaHe just means the speed is what the car reports through the REST API rather than using the GPS of the iOS device which wifi ipads don't even have.
