Maybe I missed something (sorry if I did), but where did these scaling factors come from?For those that do not speak "code", the 8 data bytes (8 bits each) can be called D1, D2 ... D8.
The D1 value is an Index value, a counter for the 24 0x6F2 messages.
Each message has bytes D2 through D8 (7 bytes) used for 4 values, of 14 bits each.
So, string out the 8 bits of the 7 bytes as 8 x 7 = 56 bits, and use those bits, in groups
of 14 bits, as the 4 voltage (or temperature) values (14 x 4 = 56).
The 14 bits for the voltages are an unsigned integer. Multiply by 0.000305 to get cell voltage.
The 14 bits for the temperatures are a signed integer. Multiply by 0.0122 to get degrees C.
Thanks to wk057 for the exact scale factors.
I've actually got a few modules sitting in front of me and have interfaced with them over UART using an mbed microcontroller. I can read the cell voltage and temperature registers, but when I used the scaling specified above, my module voltages (sum of all 6 cell voltages) is too low by about 2V. Another resource (Model S BMS hacking) specifies a scaling for voltage of 0.000381493 if you dig through their Arduino code. This value gives me a module voltage that's too high.
What's odd is the discrepancy between each module's reported voltage and actual voltage measured with a DMM does not seem to be linear - applying a correction to make the scaling of the reported voltage match the actual voltage for any particular module will make the discrepancy greater for other modules.
I'm unsure if this is just a sensor issue or small inaccuracy in the voltage scaling.
Great! Thanks for the detailed information.
Thanks for this. I've ordered parts and will give it a try.Hi mspohr,
if you are still interested to make it work with arduino UNO and MCP2515.
I have just connected a CANbus MCP2515 chip (bought from ebay) to an Arduino UNO and could read loads of data from my tesla model S.
Paid around 1.5$ for the chip and used the following canbus arduino lib from fowler
https://github.com/coryjfowler/MCP_CAN_lib
You can easily use the examples already provided and filter by the message ID you like.
works like a charm. Don't forget to set the correct clock speed, on those cheap chips it's 8MHZ not 16MHZ.
So far I could read all battery information along with other stuff too, don't seem to miss any frames here.
Havent tried yet to capture data while driving, where most probably there will be more frames on the bus.
cheers
Would like to get your Arduino code. ThanksI got this one, from that supplier.
MCP2515 TJA1050 EF02037 CAN Bus Shield Receiver SPI Controller IC for Arduino | eBay
Oh yes and you cant reuse collin s code as is.
I can share the code for arduino uno which works with the library posted above.
The code just displays the battery cells voltages and temperatures in a similar way as collins one.
Basically it reads the 14 bits values from the 56bits number contained in a canbus frame and converts them into voltages values.
A big thanks to collin for deciphering id 6F2 and jason for the conversion factor :14bit to real voltage.
Cheers
Jack, do you happen to know at what "Tesla SoC" your screenshot was taken? I see a cell voltage between 3.89 and 3.91 with 3.899V as the average.
What I have been trying to find out is at what "Tesla SoC" the cells are at 3.92V. I would like to set this SoC as my daily charge level when I don't need the range.
According to this article on the Battery University website: "In terms of longevity, the optimal charge voltage is 3.92V/cell. Battery experts believe that this threshold eliminates all voltage-related stresses; going lower may not gain further benefits but induce other symptoms."
Thanks very much. Looks good.considering that an arduino uno costs around 10$ and the CAN bus chip 1.5$, it does what's supposed to do.
it processes all battery frames, always and will display all voltages cells and temperatures, without issues.
if you want to do more processing in the code and output to serial monitor more info, then the arduino uno (atmega) isn't fast enough.
For example, I noticed that if I print too many variables to serial monitor then the arduino will slow down too much and can't catch up with frames.
But as I said, for the purpose of displaying BMS info, it works.
enjoy
For i As Integer = 1 To 8
value0bb1(i) = Convert.ToByte(newCommand.Substring(((i * 2) + 1), 2), 16)
Next
Dim value0bbit As Integer = (value0bb1(8) << 8) + value0bb1(7) 'joining C700 (shifted left) + C7 to get C7C7, shift this right 2 times
Dim value1bbit As Integer = (value0bb1(7) << 16) + (value0bb1(6) << 8) + value0bb1(5)
Dim value2bbit As Integer = (value0bb1(5) << 16) + (value0bb1(4) << 8) + value0bb1(3)
Dim value3bbit As Integer = (value0bb1(3) << 8) + value0bb1(2)
Dim izracunaj0bb1 As Double = ((value0bbit >> 2) And &H3FFF) * 0.000305 ..naj0bb1 (bat 1)
Dim izracunaj1bb1 As Double = ((value1bbit >> 4) And &H3FFF) * 0.000305 ..naj2bb1 (bat 2)
Dim izracunaj2bb1 As Double = ((value2bbit >> 6) And &H3FFF) * 0.000305 ..naj2bb1 (bat 3)
Dim izracunaj3bb1 As Double = (value3bbit And &H3FFF) * 0.000305 ..naj3bb1 (bat 4)
I am new here but is this a screen I can vie win my 2014 model S or is it from a diag tool?Awesome Jack, I was trying to map the bits to actual voltages but with lack of time. Good job!
- - - Updated - - -
Just to others, this is the data we are looking at, visually:
You've posted to a very old thread. No, this info is not on the car screen. Most people now use Scan My Tesla to view this data.I am new here but is this a screen I can vie win my 2014 model S or is it from a diag tool?
